Results 1 to 8 of 8
Thread: Water numbers
    Water numbers
    Here are my pool numbers, let me know if I am headed in the right direction please.
    FC 6
    CC 0
    TC 6, if I'm understanding this correctly
    PH 7.5
    T/A 100
    CYA 50
    Pool Temp. 85 degrees. Last week I did a overnight FC test and had no chlorine loss
    I do have a question.......I am not using any type of automatic chlorine dispenser. Is this okay, and does others handle their pool chemical this way? I am only doing the BBB method.
    thanks!!!
    Carlotta (aka Clodda)
    Oval AGP 18x33x54 18,000 gal.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    22,553
    Re: Water numbers
    Looks like you've got a good handle on it.
    A lot of people don't have any type of dispenser. They pour bleach right out of the jug into the pool. I did it that way till I get the Liquidator.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Water numbers
    Hi Clodda...
    Goodness those numbers look pretty good to me so long as you are using a reliable test kit. I plugged everything into the pool calculator and your FC range is 4-8 so you're right there in the middle. My usage went up significantly this last week so I make sure I bring it to the upper number of my range every night and even bumped it a couple past while family was here visiting.
    How does your water look?
    As for your question...I do all my chemical additions manually an usually in the evening. I can't justify the expense of changing out my tablet feeder and adding an auto system nor can I go for a SWG. It's easy to add the chlorine for me. I'm also fortunate that I have a neighbor who used to have a pool and she's already said she has no problem checking on things while we are out of town and adding bleach.
    If I were doing a new install I'd probably consider a SWG but I'm not worried about it now.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Water numbers
    Quote Originally Posted by clodda43
    FC 6
    CC 0
    Yup
    PH 7.5
    T/A 100
    TA is slightly high. I suspect that your pH will tend to drift up. With application of MA to control pH the TA will come down naturally over time.
    Without seeing your CH number it is impossible to tell where you really want to target your TA to keep CSI in range.
    CYA 50
    to reiterate what poolgirl22 said, with CYA = 50, your FC range is 4-8. This means you never want to drop below 4, so target the high end when you add chlorine (overshooting a little is OK).
    Jealous
    Yup. Even though it seems like everyone on the forum has a SWCG, I bet us jug dumpers are in the majority,
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Water numbers
    Jug Dumper.
    That's going in my signature line. I love it.
    Re: Water numbers
    Poolgirl22.......I bought the TF100 test kit. I was intimadated by it at first. I've had it for two weeks now and feel more comfortable with it. Still struggling with the bluebox kit, but only the yellow for the FC. My water is crystal clear and sparkling, it has never looked better. We let the pool store talk us into a perma salt system, cheaper, easier, blah, blah, blah. Not, it was double the cost because of our pool size. Funny how they forget to tell you those type of things up front. But we are now on the right track. I tell all our pool owner family and friends about TFP. I hope everyone has a great pool season.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Water numbers
    Glad to hear you have a good test kit. It's my favorite purchase for the pool!
    I rarely use the chlorine test in the blue box because it's Total Chlorine and I want to know Free Chlorine and Combine Chlorine individually and the yellow is just too hard to get a good distinction. I always use the FAS DPD because it's more accurate and for my pool there's a big difference between a FC of 5 and 10. I have to come up to at least 9 (my high end of target) each night because right now I'm back at 4.5-5.0 by days end. We are heavy pool users and I'm in full sun from 9 am to 7 pm.
    You seem on the right track! Isn't it a great feeling? I, too, share this site with all my friends. Not sure how many of them come here, but I'm hooked! Have fun doing not so much to your pool!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Water numbers
    Quote Originally Posted by poolgirl22
    Jug Dumper.
    As Dave Barry would say; "that would be a good name for a rock band"
