Results 1 to 8 of 8
Thread: Started conversion, but some questions
    I started my conversion today. Water is at 15ppm. My question is there is a off white scum floating on the top. The water is also a pea soup color and I cannot see the bottom, but I expected this just not the scum. Pool is above ground 21in, 52 in deep.
    THANKS A TON FOR ANY HELP.
    Jen
    Jun 2007
    Charleston, SC
    151
    Some people find a lot of solids coming out of the pool during the conversion, and you should be vacuming to waste as much as possible.
    You have the filter running 24/7 right?
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    30,419
    Hi, Jen,
    Yeah, you might see a lot of strange things during conversion. The principle to remember is...STAY THE COURSE!. Keep you FC up there and keep vacuuming/skimming/filtering doing whatever it takes to get the junk out of your pool. That will only speed your process.
    (the scum could be a result of algaecide or possible something else.....doesn't really matter....it's in there and you've got to get it out with the process you have started.)
    Thanks
    I am running the filter all the time and vacuuming to waste as much as I can. I'll keep ya'll posted on how it is going.
    Thanks again
    Jen
    Things seem to be going good. water is still green but I can see the bottom, and not as much scum. What does adding water do to the process?
    Jen
    it will lower the concentration of the baqua in the pool, but you will still need to get it all out. So nothing really, except the increased gallonage will make you have to add more bleach to reach/maintain your shock level.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    I'm up to 21 containers of bleach. 10 of them were the regular size,11 of them were the big size. Is this extreme or is it different for everybody depending on how much baqu stuff is in there?
    Jen
    Guest
    pretty much normal. It can take a lot of chlorine to destroy all the biguanide.
