Thread: Ugh I'm draining pool
    It's about 2inches unlevel in 1 spot the posts look like there leaning there so I'm draining so we can fix this, so I need to completly drain it to dig out and move the post?
    14X42 Intex Ultra Frame
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    Re: Ugh I'm draining pool
    The best way is to drain and move the pool and re-level.
    Easy way to level the area, use a 10' 2x6 with a level attached and one end pegged in the middle of the pool area, swing the board in a circle scraping the high spots down and filling in the low spots (make sure to tamp those low spots down).
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
