Thread: Problem with my flow switch
    I think I am having a problem with my flow switch for my aqua Rite, I saw in a post here that you can by-pass the switch to make sure if you have a problem or not, Can some tell me hoe to by-pass it Please..
    Thank you
    billybrobob's Avatar
    Apr 2008
    NW Florida
    Re: Problem with my flow switch
    The flowmeter completes a circuit. A phone jack will work to make a "pigtail". Just jump the two center wires together (please double check: look at the socket. Should only be two contacts for the center wires). Works very well to troubleshoot. If your SWG is only powered when the pump is on, say through your timer, you might use instead of flowmeter. However, if your pump siezes and the power stays on, you will have toxic gas buildup.
    40,000 gal pool, Goldline SWG, 1.5 hp pump, sand filter, plaster w/epoxy paint.
    Mar 2009
    Huntsville, AL
    I don't think that this thread tells how to bypass the flow switch, but it does have info on how to get a (relatively) inexpensive replacement should you need it.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
