Results 1 to 9 of 9
Thread: Total Alkalinity
    Dayton, Ohio
    79
    Total Alkalinity
    The pool is up and running as of yesterday. Started my 4 day shock process last night.
    Tested this am and
    Cl 2
    pH 7.4
    TA 300
    Added liquid chlorine per the pool calculator. Pointed my return up to help aerate. I have read so much that my eyeballs are spinning in my head! Can someone just tell me what I should be doing at this point for the TA?
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    30,414
    Re: Total Alkalinity
    cm,
    The best explanation is found in Pool School....."How to Lower TA"
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Before doing anything else, retest your TA, wiping the tip of the dropper bottle about every 3rd drop with a damp cloth. Some people experience static build-up issues with the test which can lead to excessively high results.
    If your TA is really that high, you want to do the aeration while the pH is low. Read the Lowering Total Alkalinity
    article for details.
    Mar 2010
    Spring, TX
    1,082
    You will also need some patience when doing this as it can take a while.
    Here is the direct link to pool school for lowering TA as mentioned above by duraleigh.
    pool-school/lowering%20total%20alkalinity
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Dayton, Ohio
    79
    I wiped as you said with a damp cloth when titrating and it made no difference. I am planning on dropping my pH to 7.0 with muriatic acid and aerating. It said it could take days or even weeks so I will have to wait and see.
    BBB
    Mar 2010
    Spring, TX
    1,082
    When I did mine it was around 180 and took about a month to get around 100. I was only able to lower every few days as I did not have strong aeration. If you can make the pH rise faster, then you can lower it back down which will drop the TA.
    Feb 2010
    Houston, TX
    271
    Quote Originally Posted by mynewpool
    Couldn't have said it better myself. The more aeration you can get, the faster you can get that TA down.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Dayton, Ohio
    79
    This am my chlorine was a solid 5 (maybe more it only goes up that far) My pH was still 7.4 and TA is down to 280/290 (after having adding muriatic acid last night and aerated with my return jet pointed all the way up). I guess this is going to take a while. I have tonight and tomorrow to finish with the dichlor. Is it ok that I am trying to get the TA down in the middle of doing this?
    Thanks!
    BBB
    Aug 2009
    SW Wisconsin
    518
    uh yeah..its gonna take a while. I started dropping my TA the end of april..it was at about 210...I have been adding MA and aerating ever since..and my TA as of June 1 is now at 130...so it does take time.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
