Results 1 to 8 of 8
Thread: Still Foggy
    Still Foggy
    My numbers
    FC 4
    CC 0
    pH 7.2
    T/A 80
    CYA 30
    Should I add some baking soda to raise both my pH & T/A?
    Lori
    21,200 Gallon AG Sand Filter
    30,426
    Re: Still Foggy
    1. I would leave your pH and TA alone
    2. Baking soda will not raise your pH but will raise your TA.
    3. What's still foggy? Your water?
    Re: Still Foggy
    My pool water is murky/foggy but blue.
    When I checked the pool calculator it sais: Note: Adding baking soda will also raise your pH
    Do I just need to wait?
    Lori
    Re: Still Foggy
    Here is a pic to give an idea of what i am talking about
    Lori
    30,426
    Re: Still Foggy
    Hi, Lori,
    Good pic...that helps
    The murkiness will probably slowly go away simply by filtering as you suggest.
    It would probably be a good idea to elevate your FC level up around 6-8ppm as long as the cloudiness is present. That way, if you still have some living organics contributing to the cloudiness, the additional chlorine should help the clearing process go a little faster.
    I misspoke about the baking soda....I'm sorry. That said, I would leave both TA and pH right where they are.
    Re: Still Foggy
    Baking soda only raises the PH a tiny amount. Normally you can ignore that.
    I agree with duraleigh, raise FC to just over the high end of the normal range and see if things improve day to day. If your FC level is falling quickly, it might be algae just getting started. It would also be a good idea to do a CH test, just to make sure your CH isn't really high (which could cause the cloudiness).
    Re: Still Foggy
    Can you lower your CH w/o draining water?
    I will test in the morning and post my results.... I have a funny feeling that is what it is.
    What range do I want to be in?
    Thanks for your help
    Lori
    Re: Still Foggy
    The two ways to lower CH are to replace water or to get a reverse osmosis treatment.
