Results 1 to 8 of 8
Thread: Acid Magic
    Acid Magic
    Any problems using Acid Magic in lieu of Muriatic Acid?
    See http://www.certol.com/AcidMagicHome.aspx
    -Steve, Westford, MA; 31,326 gal 21' x 41' IG Imperial 1000 Series vinyl pool
    96 gpm Hayward DE-4800 filter,1.5HP,3hrs/day,$0.72/hr;TF100 test kit, Borate & Salt strips
    South Central NJ
    3,192
    Re: Acid Magic
    None known. It costs more but if the MA's fumes bother you, may be worth the difference.
    Acid Magic uses unkown buffers to reduce the fumes. We don't normally like unknowns added since BBB is all about controlling and knowing what is in our pool.
    Scott
    Owner of - PoolGuyNJ LLC
    Feb 2008
    Denton, TX
    5,061
    Re: Acid Magic
    As PoolGuyNJ mentioned, Acid Magic doesn't fume to the degree that plain ol' muriatic acid does and this may be an attractive thing for you. The problem with Acid Magic is that we don't really know what else is in there. According to the MSDS, it is mostly hydrochloric acid. We just don't know what else has been added to it and despite our asking, Certrol will not divulge the complete formulation to us citing "trade secret". Because of this, we really cannot endorse Acid Magic as being a suitable alternative to regular MA. If we knew what was in there, completely and totally, that might be different. But as it stands now, we just don't.
    Re: Acid Magic
    I think the availability of MA will be a problem for me.
    Last year I looked in Home Depot and Lowes and they only had alternatives. I finally found MA at my local Ace Hardware store.
    But when I went there this year, they had this Acid Magic.
    I think retailers are moving to these alternatives because of safety and liability issues.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Acid Magic
    True Value has MA on sale week for $5.99 in their paint section. Just happen to be looking at the weekly flyer
    Feb 2008
    Denton, TX
    5,061
    Re: Acid Magic
    Quote Originally Posted by dmanb2b
    dmanb2b brings up a good point in that you may have to look elsewhere for it. It goes without saying though that some of the harsher chemicals are getting harder to find and this is often the result of the ebb and flow of the political tide in your particular locale. If it hasn't been banned outright for some reason, the painting section may have some and it can also be found in places that sell masonry supplies since it is frequently used to remove mineral and hard water staining from brick surfaces. You may also find some only to discover that it is in reduced strength. That means that you will need to adjust your dosage volume accordingly. Be sure to note the concentration on the container.
    Re: Acid Magic
    Brick masons use it to clean off the mortar dust and splatered cement from a brick wall. Try asking a local concrete company where they get thiers.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Acid Magic
    According to this fact sheet they have buffered the acid in such a way that it can increase inorganic phosphates (aka orthophosphates). So be careful when using this acid in the pool. Though phosphates should not matter, the amount could accumulate enough to cause calcium phosphate scaling especially in high CH environments. Also, if your pool was low in phosphates before, then the increased phosphates will make the pool grow algae faster if you let the FC/CYA ratio get too low.
