Thread: Vinyl Pool Wall Very Rough
    Used our above ground pool for 1st time today. The vinyl pool liner wall feels like sandpaper. I used a brush but it did not have any results..still very rough. Any thoughts as to what could be causing this? Is there a fix? The liner is about 3 years old. Pool is 52 inch deep and 28 foot round.
    13,500 Gal., Swim Pro SW256T Sand Filter, 24' Dia. x 54" A.G., 1 1/2 HP Hayward Pump, Hayward CL-220 Inline Chlorinator, Tri-Chlor As Primary Sanitizer And Bleach To Shock
    30,432
    Re: Vinyl Pool Wall Very Rough
    Hi, Mike,
    Welcome to the forum. It's a guess but the most likely cause is calcium scaling....the result of very high pH over a long period of time.
    Posting current test results may give us an indicator but the water may have been balanced by now.
    A possible cure may be to CAREFULLY lower pH to 7.0 or so and see if the deposits eventually dissolve.
    Appreciate your welcome to forum....and thanks for you thoughts on this. I will give it a try. The pool is balanced. I've been running filter for 3 weeks...had quite a bit of green algae..I did not cover pool for winter. I will take my water in for testing and post back results. I did add quite a bit of chemicals after the first few testings...to get lined out. The water has been milky for 3 weeks now...pool shop said would clear up when we got in pool. We had quite a bit of use over weekend that is how I found rough walls..still cloudy. Thanks again!
    30,432
    Post up those test results....it may give us some further clues.
    Tested pool this afternoon here are my results:
    Temp: 75
    Sat Index: -0.5
    TDS: 100
    CYA: Not tested
    Tot.Chlorine: 1.3
    Free Chlorine: 1.3
    pH: 6.8
    Tot.Alkalinity: 156
    Adj. Tot. Alk: 156
    Tot. Hardness:241
    Pool water is clear about 1 foot down, and then is still very cloudy..cannot see bottom.
