Thread: Heating questions for a used hot tub
    Jul 2009
    Richmond, Michigan
    12
    I was given a used Acura 5 person hot tub. Not sure how old it is, but it hasn't been used in several years. I wired it for 110v. Everything seems to work except for the heater. The manual shows it can be run on 110v or 220v. Could the voltage be the issue? I have the heater coil out of the unit right now. Is there a way to test it using a multimeter or something else? I don't want to replace it if it's in working condition. Thanks!
    15 x 24 AG Vinyl, 10,500 Gallons, 1 hp StaRite Pump, Cartridge Filter
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Heating questions for a used hot tub
    I am absolutely not an expert, but I bought a used hot tub several years ago. I'm going to use some pretty technical terms here to explain what happened.
    It got wired for 220 but it wouldn't heat very well. We later found out that one of the thingamabobs wasn't properly tied to the doohicky in the breaker so the tub wasn't getting a full 220v. Once the thingamabob was attached correctly we got full heat.
    So, in my non expert opinion I would say the answer to the question may be yes, the voltage matters. Hopefully someone more knowledgeable than me will be along and answer your questions. In the meantime I hope I provided you with some comic relief to get you through.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Jul 2009
    Richmond, Michigan
    12
    Thanks for the "technical" help! I did get some comic relief from it!
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    It should be able to run on 120V if the manual says that it can be. Test the heating coil with an ohm meter or continuity meter / light. How was the tub wired originally 120V or 220V? Also, check the thermostat to see if it is actually calling for heat. It could be a bad thermostat.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Jul 2009
    Richmond, Michigan
    12
    Thanks for the info. When testing with an ohm meter, should I be looking for high resistance or no resistance across the heating coil?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by beachyoest
    Fairly low. 99.9% of the time you'll see an open if there is a problem.
