Thread: What do I do?
    Apr 2010
    Central Illinois
    205
    What do I do?
    Hi, I just bought an Intex easy set 15 x 42 pool. I've never had a pool before!!! My main question is this, As soon as it fills can the kiddies go swimming? I'd like to do the BBB method, I tried the calculater(I'm a little confused by it) but I have not tested yet. I did buy a basic ph and cl tester. will that be okay til i get a tf-100? I really need to succeed with this pool because it is my tester pool before jumpin into a large pool. Thanks in advance
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    22,553
    Re: What do I do?
    Welcome to TFP
    Read pool school on temporary pools and that'll get you started.
    Before you can swim you'll need to balance it. What that entails depends on your fill water. If you're filling it from a public water system you can get a water report from the system and you can post the numbers here and we can help you. You'll need some chlorine in it and the pH will need to be between 7.2 & 7.8.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What do I do?
    Assuming you have reasonably good tap water, for a 3300 gallon pool you will need to add about 1 pound of dry stabilizer to keep your chlorine use down, this should put your CYA around 40 (a good starting point), initial chlorine dose should be around a quart of 6% bleach, you will need a test kit soon afterward to maintain it at the correct level. And you will need to adjust the PH, again if you have good drinkable supply water, your likely in the 7.something range, the general advice is pools should be somewhere in the 7.2-7.6 range, a simple $10-15 drop test kit will tell you all you need to know on this, don't trust the dip strips. You will need a better kit to fine tune and tell when to shock (when combine chlorine gets too high) , alternatively you can use the cheap test kit to keep the total chlorine at good levels, and shock often, more often than you need to, I would suggest using a non-chlorine shock if you go this route, like HTH shock N swim, this way you don't have to wait a long time for chlorine levels to fall on a small pool it is cheap enough.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: What do I do?
    This is the article which outlines the steps you need to follow.
    http://www.troublefreepool.com/pool-...ary_pool_guide
    For your size pool - if you should develop green or cloudy water, it will be much simpler to simply drain and refill and start over than try and treat it.
    If you maintain the proper levels and follow the steps in the article you should have a trouble-free summer.
    Re: What do I do?
    I think if you fill it with city water (I know nothing of wells) you should be able to put in some bleach, mix in the bleach by walking in circles in the pool and then across the pool, wait 20 minutes, and let the kids swim. That is, assuming they can take the cold of a freshly filled pool!
    As to how much bleach, a 15 x 42 Easy Set is about 3284 gallons if filled to max (to bottom of ring). Assuming you have no CYA (you shouldn't unless you added some) you would want a minimum FC of 2 and I'm guessing a maximum of 4 or 5. To get from 0 FC with 0 CYA to 3 FC, add 21 oz of 6% bleach. That should get you through day one and let people swim. When you are done swimming, or that evening when closing pool for the day you could add another cup or two of bleach.
    Then, go buy some dichlor and starting the next day follow the instructions on the temporary pool school article for Intex pools. You'll gradually build up CYA with dichlor (which will also add FC) and then keep your FC in the target range thereafter by adding bleach.
    In short: Fill; add bleach; mix in bleach; wait 20 minutes; swim; add a little more bleach; get dichlor; follow pool school for temporary pools. In the meantime, test often to be sure FC never falls below 2 (or whatever your then-current CYA reading mandates -- if it does, add more bleach. If getting too close to 5, back off on the bleach a bit but be aware that until you get some CYA in there FC will disappear quickly so stay on top of it. You want to start each day with more than the minimum FC so that as sunlight eats it up (which will happen quickly til enough CYA) you don't fall below the minimum.
    Enjoy, and check back to this response to be sure no one has corrected me on any part of it -- I am pretty new so take my advice with that in mind. It is about how I manage my 15 x 36 Intex, however.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
