Results 1 to 12 of 12
Thread: Liner pulled away from coping - is this a DIY?
    Aug 2009
    Central PA
    64
    Just discovered a ~5" section of liner that has pulled away from the aluminum coping. It appears that there's a channel back inside that should lock the liner in.
    (sorry, I forgot to flip the last pic over )
    The pool is a bit over a year old, and the pool company says it would be a service call ($95) to fix.
    Can I fix it myself? How? Any wisdom appreciated!
    Hope everyone's having a great holiday. We've been enjoying the water!
    Steve
    29,000 gal. vinyl in-ground mountain lake (freeform); Hayward DE filter, 2 skimmers, AutoPilot SWG, 2 - 4 X 20 Fafco Solar Bears with Goldline control, Aquabot, LoopLoc winter cover, Pool installed March 2009...
    Mar 2009
    eastern washington state
    275
    Re: Liner pulled away from coping - is this a DIY?
    yes it is a DYI, but I have never done it.. But from reading on here its not that hard to do..most of the time
    someone will come along that can help
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    You, you should be able to do that yourself. You want to do the work on a hot sunny day, to help the liner stretch. Mostly you need some brute force to get the liner back into the track, pushing at the proper angle is important, but tricky to explain. Once the liner is in the track, you will want something to help lock it into the track so this doesn't happen again. You can use liner lock, or pennies (which work just as well).
    Aug 2009
    Central PA
    64
    Thanks for the replies! Three questions then:
    1. Does one use any sort of tools (I'd be concerned about poking holes) or just fingers (& cussin')?
    2. Does it go back in with the coping left in place just as it is?
    3. The pennies (or liner lock) get inserted after the liner's back in place, into the slot, "on top" of the liner tab?
    Quote Originally Posted by Steverino
    I've been able to fix mine quite easily by heating up the liner just below with a hair dryer for about 20-30 seconds.
    DO NOT DROP THE HAIR DRYER INTO THE POOL!!!!!!!
    After it's heated I just pull it back into place. It should lock in by itself if your track is still in good shape. I never use liner lock of pennies or anything else.
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Should ought be DIY
    take a look at this and feel free to ask more on the advice therein
    Luv& Luk
    -Ted
    Aug 2009
    Central PA
    64
    Thanks for the tips - I'll give it a go. I hate spending $ on something I can do myself (with proper information - like not seeing if the hairdryer can self propel thru the water )
    I kind of wonder, though, if it came loose once, won't it just come back out again? Guess we'll see!
    Ashbourne's Avatar
    Western Piedmont, NC
    109
    I just had a new liner installed a few weeks ago. The following week I had two 6" spots, pretty much right next to each other, and for that one I called the installers back to put it back in. I tried myself but I couldn't pull it up (it wasn't very warm outside) and I really didn't want to mess with it since it is a new install.
    This morning I went out and there was another spot in a different place, bigger than yours, and I thought about calling them back again. By the time I went back out there this afternoon it was hot and I figured I would try it myself...made all the difference. It pulled up very easily. I started on one side and bent the top/white part to a 90 degree angle and pushed it back in. Then I ran my thumb up from the wall below to make sure it was seated all the way in. I did this, moving all the way down, until it was all back in. It didn't come back out.
    (I am female by the way, not a big strong guy.)
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
    Aug 2009
    Central PA
    64
    Hey - thanks for the encouragement, Ashbourne! The only part that makes my location tricky is that it's in the deep end, so I can't stand in the pool and push up & in with any sort of leverage - I think I'll have to work leaning over from above. If I pick a hot day, there's two plusses - 1) the liner will be more pliable, and 2) if I over-leverage & fall in, it'll be refreshing!
    Ashbourne's Avatar
    109
    The one I fixed myself was in the deep end too - everything I described I did was from a position on the deck above it. Good luck!
    Aug 2009
    Central PA
    64
    Fixed!
    Turned out easier than I first thought based on my earlier testing. Today was hot & sunny and after dinner I gave it a go - used a wooden paint stirring stick as a gentle persuader. It was blunt enough to not poke the liner much but rough enough to grip a bit and thick enough not to break. (Plus free and available...) I was surprised how readily the bead re-seated once in position.
    It will be interesting to see if it stays put or if I will end up needing some liner lock to keep it there.
    Thanks again everyone for the helpful tips!
    Ashbourne's Avatar
    109
    Yes! Now that $95 can go to much better use!
    The spot I fixed has stayed in place since I put it back in...so far so good. Hope yours does too.
