Thread: Test kit chems
    Test kit chems
    Hi, no change in color, my question I have ran out of the R-0871 is the R-0600 that is used in the Taylors test kit
    the same chem and will it do the same job till I get more R-0871.
    Regards b/d
    16x32 a/g pool 16400 gals
    r-0871 is titrating reagent used in fas-dpd chlorine test, r-0600 is Orthotolidine i am no expert but if they have dif chemical names and they are both Taylor i would have to say the are not the same. hope this helps Ric
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    no, they are not the same at will have to get more of the R-0871 before you can do another FAS-DPD test.
