Thread: Ph and ta
    Daytona Beach, FL 32117 USA
    35
    Ph and ta
    I lowered my ph from 7,8 to 7 to also reduce my ta. This was on 5/27. On 5/29 I finally. Got it down to 7.0 when tested at 7 pm. At this. Time my ta was 70. I aerated the water and on 5/31 my ph is 7.3 and ta 80. This tested at 8 am. I turned the return down towards the bottom and want to try ro keep the ph around 7.3 and ta around 70. What do I need to do?
    12k Gal. Kidney IG pool (Built around 1964 screened enclosure?), Tahoe Blue Diamond Brite (Added 12/2007), 1 hp motor, Sta-Rite P2 pump, Hayward C900 paper cartridge filter, Resilience SWG PSC-3 SCC 25 Element, Dolphin Robatic Cleaner, Lamotte ColorQ Pro 11, Taylor K2006C, Lamotte Tracer PockeTester PH/TDS/SAL, purptiger
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Ph and ta
    Just keep testing and adjusting. When you lose water to evaporation, the numbers will change. And they'll change again when you refill. The only way to know how much is by testing. You'll spend less time testing and adjusting every day than you will brushing just once a week.
    Trouble-free doesn't mean maintenance-free.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Ph and ta
    Yep, I'd test pH daily at first to make sure it has stabilized. It is likely to change slowly over time and you just keep an eye on it. As you get used to how the pool behaves, you can test less frequently. If pH is still climbing faster than you like, you can lower TA a little more.
    --paulr
    BBB "Intermediate Swimmer"
