Results 1 to 9 of 9
Thread: above grond pool newbies
    Hi all, We are just filling our above ground pool which is 12ft by 24ft and 4ft deep, we may require a bit of assistance. So if you have any tips we would love to hear them please
    26Kgal IG Vinyl liner
    Hayward 1HP Superpump
    Hayward Pro Grid 4800 DE Filter
    thepoolcleaner pressure side cleaner
    1. Get a good test kit, check my signature.
    2. Read the stickies, also linked in my signature.
    3. Use Jason's calculator (in my sig) to figure your pool volume and how much bleach, etc to add to balance your water.
    If you need help, post a set of numbers (FC, TC, pH, TA, CH, CYA) and we can assist you!
    Welcome to TFP... you are on your way to a trouble free pool!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Casey's Avatar
    SW PA
    10,438
    What Mermaid Queen said and most of all, ENJOY your swimming experience!
    Arizona
    924
    Hi and welcome to the group!
    You'll find a lot of good information on this forum. It may be a little confusing at first, but in a few days, you'll be an expert on pool care.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Ohio
    217
    hi cal and matt
    The Mermaid Queen is giving you great advice. #1 the test kit is the most important thing you can purchase for your pool. get one and use it 2 times a day untill you get used to it. The testing results will help you learn your pool 100% there is little help for your water on a forum with out the tests. I am just trying to say how important these test are i feel the kits should come before the pool. Keep reading and ask all the questions you need to everybody is willing to help you. Also read about the equipment and the chemicals on the forum it will teach you a lot. Thing can be a little overwhelming at first but it will all come quickly Good luck and welcome
    Ric W
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Make a habit of doing a bi-weekly "systems check" for leaks, loose fittings, rust, electrical issues, etc. Those are the things we forget about when we are enjoying our pools so much and they are the things that can cause the biggest PIA disasters. A cracked fitting or small leak can ruin the pool or your swimming season because they usually turn into HUGE problems by the time we notice UNLESS we do a regular systems check.
    Been there, done that - too many times already!
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    All, many thanks for your useful and welcoming responses _ you`re right, it does seem a daunting experience balancing the water initially .
    It`s good to know there`s non-text book advise along with experience and common sense out there....I`m sure we`ll be in touch !!
    Thanks for now,
    Matt
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi Cal and Matt welcome
    Your off to a great start! Keep reading those stickies!
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    new to the forum
    Hi all its Cal here well the pool is up and running and for the first few days chemical balance was fine but now
    chlorine is white on the test strips, but water is clear and warm although we have not yet used the heater, I have had a look at the pool pics they are all excellent pools and make my above ground intex oval 12 by 24ft look rather silly. By the way we are from England noticed most af you are American. Thank you all for the help so far.
