Thread: Spent the w/e digging just need to verify something please
    Ok so I spent yesterday digging a 50 foot 18" deep trench for filtration lines so I could put the filter and pump in an old metal shed I have (man what a ton of work).
    Trench has about a 1" layer of fine sand on the bottom and then 2 2" pipes laid in it with properly glued couplers and 90s (trench is an L shape 30' from pool to a right turn and then 15' from there to the shed). Once reviewed by the county I will cover the pipes with more sand and then fill back in with dirt (of course after I verify for leaks).
    My question ....
    The filter is a Waterco T450 165lb Sand filter with a Waterco Aquarite 2HP pump.
    Pool is a 27' Round Above Ground Pool.
    Will this pump be able to handle this distance and perform well or do I need something different?
    I would also like to add in an SWG system to this as well so please lmk if this would still work with the above equipment
    Lastly in your estimation how many hours per day should the pump run?
    Thanks
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: Spent the w/e digging just need to verify something please
    To help in the restriction of water flow to and from the pump I would of used 2-45 degree fittings per line instead of a 90 degree elbow.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Well I did some research before I laid the pipe and connectors and read that someone had done the calculations on using regular 90s vs 90 sweepers (I know not the same as 2 45s but its closer) and there was very little difference in rates which is why I just did regular 90s
    I could switch out to sweepers but not 45s if it would make any difference.
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I don't believe you'll have any problem. I had a 1HP pump with about that much run before I built my poolhouse, and had no issues.
    I would suggest that you carefully measure your couplings from a landmark that won't move. That way if you ever get a leak you can dig them up and not have to hunt for them.
    That should be pretty easy as things worked out almost perfect for 10 foot increments -- i.e. from the 90 elbow to the pool to the coupler is 10 feet, then another 10 foot length, then a 3rd 10 foot length then a 90 then a 10 foot length then a 5 foot length then a 90 couple up from the ground to the shed). But good advice.
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
    Mar 2007
    Coastalish 'down easter'
    4,160
    Just to supplement John's good advice - triangulate the measurements - take a measurement from the corner of the house and another from another fixed point, so that you know EXACTLY where you are.
    Luv& Luk
    -Ted
