Thread: Please help me estimate the volume of my pool
    MomUv5's Avatar
    Memphis, TN area
    49
    I asked in a different thread, but I think it got lost in the plethora of information.
    My pool is an in-ground vinyl rectangle. We measured it yesterday and it is 18' x 36'. I'm not at all sure of the average depth. The shallow end was 3' (measured a foot or so away from the edge), and under the diving board was 8 1/2 ' (or thereabouts). I've spent some time raking around in there looking for submerged gunk and also done some vacuuming. The bottom "corners" seem to be pretty rounded. I guess that's typical for vinyl?
    I am eager to start using the pool calculator but a good volume seems vital.
    Elizabeth
    Newbie with 18 x 36 rectangular pool, estimated at 18,000 gallons, sand filter, inground w/vinyl liner, SWCG
    (Plus a houseful of nearly grown kids)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Please help me estimate the volume of my pool
    Round figures, 24000 gallons. It can vary a lot, depening on the slop of the pool. Is the shallow end long, and then a sudden dropoff? Or is it pretty much a smooth grade? Are there any steps or swim shelves?
    Use 24000 for now. If, after using pool calculator, you're not seeing the results you expect, try increasing or decreasing the volume on the calculator until the results match the estimate. You'll get close in a week or so.
    MomUv5's Avatar
    Memphis, TN area
    49
    Quote Originally Posted by Richard320
    I don't know. We can't see through the murky nastiness. The steps at the shallow end are . . . :checking visual dictionary: . . . built-in steps. When we measured the length we did not include the steps. (Very helpful, that visual dictionary!).
    Sounds great! Thanks, Richard!
    Elizabeth
    I guess around 21,000 or 22,000 gallons, assuming the walls in the deep end slope in after the first 3 feet, instead of going straight down.
    MomUv5's Avatar
    Memphis, TN area
    49
    Okay, I'm going to split the difference and call it 23,000 until it get a better handle on how it reacts to the chemicals. My test kit should be here today or tomorrow, I hope!
    Elizabeth
