Thread: Fiberglass Step Jets Installation
    I am in the proscess of building an inground vinyl pool with fiberglass steps. I read in other posts that the water movement can be an issue in the step area, and have decided to put in 2 returns. My question is where do I buy these returns? I have searched the internet and have yet to find anything. Any suggestions would be greatly appreciated.
    16 x 32 IGV, steel wall, Hayward SuperPump, Hayward 24in Sand Filter, Jandy LRZ 250K BTU Heater.
    Re: Fiberglass Step Jets Installation
    You can use a standard return fitting with a relatively small opening for steps.
    Thanks. Where can I get them?
    Most pool stores carry them
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
