Thread: I have an Intex SWG and keep getting "low salt" error code
    I have more then enough salt in the pool, why do i keep getting this error code?
    Thanks!!!
    Re: I have an Intex SWG and keep getting "low salt" error code
    Welcome to TFP!
    How do you know that you have enough salt in the pool?
    Sometimes that error will come on when the cell plates have gotten calcium scale on them. You should take a look at the cell plates and see if they have any white chalky residue on them.
    Donldson's Avatar
    NW Ohio
    2,905
    I have had the same problem. First I found out I was getting an incorrect reading from expired strips. Since I got that straightened out I added salt I got 2 new readings of 3100 ppm. I cleaned the cells, sprayed them and soaked in vinegar. Still getting the reading.
    Just wondering if anybody has had any experience with this issue.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Sometimes you can get an error like that if your water temp is low or if you haven't circulated fresh salt more than 24 hrs
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
