Thread: Help! Leaking Gasket w/ Video
    Can someone please help me fix this? Water seems to be leaking from the rubber gasket between the return and the hose. The leak only occurs when the pump is on. Is the plastic fitting removable? What can I do to get a better seal? Any help is appreciated!
    [youtube:1m8vjzkf]Y6HlSEREqNU[/youtube:1m8vjzkf]
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    Re: Help! Leaking Gasket w/ Video
    It will probably be enough to fix it if you unscrew the connection, clean and lubricate the gasket with a silicone based pool/plumbers lube and put it back together again. While you have it apart, check that all of the surfaces the gasket presses against are clean and not cracked.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    What he said.
    I'll almost bet that the rubber gasket will be stiff and cracked. The good news is, it's probably a standard size that fits on a sink drain or something and will be available at a hardware store. When you reassemble it, be sure all the surfaces are clean and that the gasket has some sort of lubricant on it (but nothing oil-base, that causes most rubber to get mushy and swell) . It may also help it seal if the rubber is warm and pliable, so leave it lay on the patio in full sun for a while. Don't overtighten it, either - you'll just squeeze the gasket out, or tear it. And then it will leak much worse. All you want is enough pressure to cause the gasket to compress a little.
    I used a channel lock to loosen the nut, removed the gasket, dried it, lined with silicon and put back together. No more leak! Thanks guys, you're the best!
