Thread: rock under liner
    rock under liner
    noticed a small rock about the size of a marble under my 27 round liner today. its jagged not smooth. I have a leveled dirt spot with maybe 3 - 6 inch sand base under the pool.
    This is my first pool. I stuck an under water patch kit over the spot just to reinforce it. Do I just deal with it if it rips or is there something else I can do? Draining is not really an option.
    Do the underwater patch kits work well.
    And right now I have no leak just a rock. guessing at some point it will tear though
    any help or advice would be great
    25,500K gallons; cartridge; IG; plaster; I'll have to look up the pump size and flow rate
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: rock under liner
    Unless you are prepared to drain and re-do the entire pool, I wouldn't worry too much about it. What you did with the patch is generally the advice that is given for this type of thing. We have had some stones show up noticably after filling our pool the time before this last one but surprisingly it was a completely different spot that got holes. If it is a brand new fill you may be able to push the stone down with your toe or heel - the patch is the next step for reinforcement. Yes, the Boxer Glue and some other kits do work very well.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2007
    MA
    165
    We had one last year I did the patch it never came through the liner
    Cheryl
    14X42 Intex Ultra Frame
