Results 1 to 7 of 7
Thread: cloudy water from return
    Central Connecticut
    159
    Most of the chemistry is within range. Still a little smell like a public pool. will test later for CCs again. Shocked last night.
    Water crystal clear.
    However, backflushed this morning and then when I turned the pump back on, cloudy water came out of the return jets for about a minute. What would cause that ????
    Thanks
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    South Central NJ
    3,192
    Re: cloudy water from return
    Probably air.
    Scott
    Owner of - PoolGuyNJ LLC
    We can give you much better advice if you post a full set of water test results.
    Central Connecticut
    159
    FC 6
    CC <.5
    TC 6.5
    PH 7.5
    TA 120
    CH 250
    CYA 20
    temp 74
    added borax 2 days ago to bring up PH
    added stabelizer last wed to raise CYA .... was at 13
    30,432
    Did you set the valve to "rinse" after you backwashed?
    On a somewhat different topic, I'm not sure you were finished with the shock process if you had to backwash this AM.
    Are you familiar with "How to Shock your Pool" in Pool School?
    Wait till it has been a week since you added CYA and then test CYA again. You should aim to eventually raise CYA to between 40 and 50.
    Other than that, your levels look fairly good.
    The smell usually comes from CC levels being above 0. It looks like you are almost there. If needed, running with your FC level a little higher than usual should clear up the last of the CC fairly quickly.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Probably insufficient backwashing. You still had dirty stuff in the lines and the valve, and when you switched modes, it went out the returns.
    Just more stuff to vacumm up.
