Thread: Intex rubber hose adapters popping off
    Anyone have a problem keeping the adapters on the rubber hoses that come out of the pool wall? Even tightened (by hand) as far as they will go, my outlet nozzle flies right off. I'm sure it's due to the force of the water. I have a 15' soft wall pool with metal frame and use the 2500 gal/hour pump (or am trying to). Any suggestions will be appreciated. I hate to have upgraded the pump and now I can't use it.
    NWMNMom's Avatar
    Waaay NW MN
    Re: Intex rubber hose adapters popping off
    Can you take a picture of the part that is giving you trouble and post it here? Perhaps there is an easy fix..
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Thanks for the reply. I cleaned the rubber hoses and the adapters well, then used nylon rope looped around the pool frame and adapters to hold the adapters at a 90' angle to the pool. All is well now.
    West Virginia
    Mine don't pop off, but can't get tight enough not to suck air.
    Ohm_Boy's Avatar
    Orlando, FL
    Not sure how to help on these without knowing which type of connectors you have. Intex pools have a couple of different connectors, some with "worm screw" hose clamps similar to automotive types (mostly on models 15ft and smaller), and some with valves that have spin-on collars much like a pipe union (generally 18ft and beyond).
