Results 1 to 7 of 7
Thread: How much does air temp affect heating a pool?
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Im noticing its tough these late spring days to bring my pool to the temp my wife likes it. 90 degrees. LOL.
    Normally my heater gives me 2 degrees every 3 hours or so. But at night Im getting nowhere near that now. In fact it will be stuck at the same temp for hours it seems.
    Our nights in NY are still in the low 60s, maybe even upper 50s. Am I basically fighting against the colder night time weather and losing?
    Or is it possible that my heater isnt giving me the same output as it used to?
    I dont remember having this difficulty heating it up in the past, but I think I waited until the weather was a bit warmer...
    Thanks
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Re: How much does air temp affect heating a pool?
    Quote Originally Posted by mitch08
    Thanks
    Pools require LUDICROUS amount of heat and air temp has a HUGE effect on pool temp rise and sustain.
    What kind of heater do you have & how much water do you have?
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by Davegvg
    Thanks
    Uncle Dave
    I think my heater is 250k btus. My pools is 16x38 inground 8ft deep end.
    I think the heater is a little underpowered but it normally seems to do the job as long as I give it enough time.
    Thanks!
    I think its underpowered and actually costing you money.
    Im guessing your pool holds about 25K gallons.
    25K gallons x 8.34 lb per gallon= 208,500lb water 1BTU heats one pound of water 1 degree.
    a 250K btu hour heater at 80 % efficiency puts about 200K btu into the water in an hour. - at best more in direct sunlight.
    IF the air temp is mild you are just under a degree an hour into the pool- or right on with your 2 every 3 hours.
    Your heat cycle takes so long you are losing a good percentage of what you put in due to evap, and environmental cooling.
    Dave Sampson
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,070
    Are you using a solar cover? I have found that using one dramatically keeps the heat in and less evaporation which equates to less chemical loss
    With the solar cover on I would normally loose 2-4 degrees
    Without the solar cover I would loose 5-10 degrees
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Sarnia, Ontario Canada
    162
    this might add some perspective on heating and pool covers http://www.energysavers.gov/your_home/w ... opic=13140
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks everyone.
    It was definitely due to the air temp getting so low overnights.
    We had a decent day today (low 70s) far from hot and the pool heater worked great.
    I guess weather in the 50s and 60s is just a bit too much.
    I dont use a solar cover. After a few days of using it I would get too lazy and it would sit in the shed
