Thread: Ready to convert!
    Aug 2007
    Jackson, NJ
    61
    Ready to convert!
    Reading all the conversion posts. Have used Baq knock-off for many years (6 or 8, I can't remember). Convenient because I travel a lot and it needs less attention than chlorine. Last couple of years I have battled algae continuously. Water is clear; growth is on walls and bottom. Getting pretty frustrated and nearly ready to convert. Obviously, I now know how.
    Only one question.............Is there NO HOPE? Has anyone out there been successful long term with this stuff?
    Stats: 20,000 gal. vinyl pool
    DE (Perflex EC 65) filter
    1.5 hp pump
    phil_d
    20,000 gal. vinyl liner pool
    Hayward Perflex EC-65 DE filter w/1.5 hp Hayward Super Pump
    Liquidator w/ 3/8" upgrade
    Aquabot Jr. pool cleaner
    From what I have hear, people can run successful Baqua pools for a few seasons, and then start having problems. Sounds like you fall into that category!
    My honest opinion, if you still travel frequently, is convert and get an SWG, which will take care of sanitizing your pool when you are gone.
    Good luck, keep us posted, feel free to ask any questions along the way, and welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    For me, the algae started in my 5th year of Baquacil--last summer. I got so fed up I closed the pool early last summer. This summer it has been a fight all season. Between May and June I used 6 gallons of peroxide shock and a couple different filter aids. I have been running my filter 24/7 all season. My water finally cleared after about 6 weeks but the algae always returns in less than a week and I spend the time I had planned to relax in the pool brushing and vacuuming instead. I even switched to the new Baquacil CDX which is supposed to maintain oxidizer levels through the month. It hasn't helped. Now I am dealing with pink slime on top of persistent algae.
    My sister is also on Baquacil. She has not been on it as long as me, but she had problems last season that carried over into this season. She also switched to CDX and cleaned her DE filter with muriatic acid, and now she feels it is under control and she is staying with Baquacil. So that might be something to try if you really want to stick it out with Baq.
    Edit: Oops, I thought my sister had DE filter, but it is cartridge. She says she used to have DE filter and has used acid to clean it in the past.
    I am starting my conversion off Baquacil tomorrow using sodium percarbonate instead of going straight to bleach for the conversion.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Sue, keep us posted on how the Sodium Percarb conversion goes... I've only ever heard reports on using bleach, and would be interested to know the differences... time, cost, etc!
    Thanks, and good luck!
    I haqve been told that if you replace most of your water and your filter media that you can keep using Baquacil and be back at the point you were at a few years ago. It does seem like a lot to go through though.
