Results 1 to 15 of 15
Thread: converting from the frog sys to bbb
    I am waiting on the test kit and our pool is green. What do I do to get started ? Help
    Re: converting from the frog sys to bbb
    Welcome to TFP!
    One approach would be to take a water sample to a pool store and get some test numbers from them without buying anything. Then post your test results and we can tell you what to do.
    Ok. Thank you. Will post with results.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Good decision
    Anything we can do to help, you got it!
    You will love your test kit once it arrives! Good Luck!
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    Yeah; my test kit arrived. O-k here's the results:
    FC 2
    cc 2
    tc 4
    ph 7.5
    t/a 110
    ch 220
    cya 40
    what do i need to do???
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    You need to shock.
    Read How to Shock (link in my sig). With a CYA of 40, your target shock FC is 16. The idea is to bring your FC up to shock level as often as possible (up to once per hour) until you are done shocking (Water Clear, CC < 0.5, Overnight FC loss <1.0).
    What kind of pool do you have? Your CH is a little low if you have a plaster pool.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Quote Originally Posted by bearclaw20
    Hey "bearclaw20" ha. hows it going?
    24 ft. round 15,000 g
    vinyl
    1.5 hp jacuzzi
    converting from frog sys.
    11,969
    Read this article:
    Shocking Your Pool
    And follow the steps...keep shocking till that CC level drops to .5 or less and the FC holds overnight.
    Post back if that doesn't make sense...
    Will do. Thanks. I'm hoping this will help the "green" go away???
    Thanks again for your help.
    How much bleach do I add every hour?
    As svenpup said, you want to add enough chlorine to raise your FC level up to 16. How much that is depends on what your current FC level is and how large your pool is. The Pool Calculator, see the link in my signature, is handy for calculating the amount of chlorine you need to add.
    Thanks again for everyones help. )
    did you get your pool cleared up?
    Vinyl Liner
    baqua goo convert
