Thread: Newly constructed first time water fill - Phoenix Arizona
    My 40k gallon pool passed inspection and is ready for water, so I started this thread for advice on initial set up. I anticipate a few days for fill time. I tested my city water with the Taylor kit and found:
    pH 7.8
    TA= 130
    CH=330
    Therefore, my plan is to simply fill the pool and start the pumps, with perhaps just a small amount of liquid chlorine as it fills. Then, I will use the pool calculator to determine how much CYA to add and put the CYA in.
    Anything I'm missing?
    40,000 gal glass tile with BBB chemistry
    Dual Pentair cartridge filters
    Scottsdale, AZ
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Newly constructed first time water fill - Phoenix Arizona
    The PH will need to be lowered to 7.4 and maintained at 7.4-7.6 with Muratic Acid.
    You can keep all your chemistry related questions in one thread
