Thread: opening pool for the first time since conversion
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I pulled the cover of yesterday, the water was clear, but the bottom of th pool is covered in dirt. I'm guessing it's just dirt. I have wanda the whale in there cleaning it up. Here are my numbers I just took, please tell me if I'm on the right track, I know I have to add chlorine, but I wanted to get the dirt out first.
    FC 1
    CC 0
    cya 30
    Ph 7.5
    TA 70-80-ish
    You guys were a great help during my conversion and I stayed sparkly clear all summer. So, I just need to know if I'm on the right track (Except for the chlorine, which I will add tonight. It just started pouring the rain down and storming.)
    Thanks bunches
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: opening pool for the first time since conversion
    You're numbers look good - add chlorine, vacume - and do an overnight test. IF the FC doesn't hold overnight you should shock.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Thanks FrustratedPoolMom,
    WOW, this year was the easiest time I've had opening the pool, you guys in here are awesome!
