Thread: Question about the pool calculator.
    Mar 2010
    Spring, TX
    1,082
    When you use the Effects of adding chemicals part of the calculator, is that amount in weight or volume? I see at the top the numbers are different when you are putting in your now and goal.
    Hopefully this make sense.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Question about the pool calculator.
    In the Effects of adding chemicals section measurements are by volume for liquids and by weight for solids and gasses. So bleach, muriatic acid, and liquid stabilizer are by volume and everything else is by weight.
    Mar 2010
    Spring, TX
    1,082
    Thanks, I never knew that.
