Thread: Opening Chlorine Reading of 12.5 ppm??
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    We closed the pool last year on Oct. 5th., and according to my journal the readings were:
    FC 27
    TC 27
    CC 0
    PH 7.6
    TA 250
    CYA 80
    Opened this morning and on a lark took a water sample and got the following:
    FC 12.5
    TC 13
    CC 0.5
    PH 7.7
    TA 250
    CYA 60
    (I'm going to address the high PH reading.)
    Is it truely possible that we still have 12.5 FC residual? I expected zero, and CYA dropped 20????? (Super sunny today, might have a bearing on the 20 unit loss compared to an October day). I can smell the chlorine in the test sample!
    O.K., the reagents are from last year, but the DPD powder and the FAS-DPD reagent should have a shelf life of 2 years. Just wanted to express my surprise and wonder if anyone else has experienced this residual chlorine "phenomenon".
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    30,421
    Re: Opening Chlorine Reading of 12.5 ppm??
    I would say more and more members are reporting residual chlorine. It's a good indicator you had a nice clean pool that was well maintained and closed properly.....Nice work!
    YOur pH is in a "normal" range but your TA is fairly high. If both remain pretty stable this season, I would suggest leaving them both alone. If your pH climbs continually, look into reduce your TA down to around 100ppm.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Chlorine will break down CYA, very slowly. I never closed and kept FC in the pool the whole time, and 20 ppm loss is the same as what I saw over the winter.
