Results 1 to 7 of 7
Thread: For those without a SWG
    Mar 2010
    Spring, TX
    1,082
    I have read that salt tends to make your water seem softer and better for the skin (or maybe I have read this wrong). For someone who uses bleach as chlorine, how would you go about adding salt to your pool or is this something you do not want to do?
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    May 2009
    Dallas, TX
    782
    Re: For those without a SWG
    You add it the same way as an SWG pool. 2000ppm is the usual recommendation for improved water feel. I did it last season, but I'm not 100% convinced I could really tell a difference. Salt is cheap, try it for yourself and let us know what you think!
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Beez
    Is that through the skimmer I would assume so it does not settle on the bottom? Also how do you test for salt?
    I added six 40 lb bags at start-up recently to get to somewhere around 2500ppm. Might be a little too much for the skimmer. Just dump the bags directly into the pool - the salt dissolves within a day or so, even if you use water softener pellets instead of granular salt (just have to make sure it is salt without additives if you are using a SWG). Pool stores or Wally World sell salt-level test strips, and of course the pool calculator can tell you how much you'll need to start.
    17' x 25' x 48" Laguna "Portable" Pool (~12,000 Gallons)
    Intex 8111 SWG, Pump, and Filter
    3 Fafco AGP 4 x 20 Solar Bear Panels
    Dirt Devil "Pool Boy" (Pool Rover Jr.)
    BBB and a SWG make my pool care really E-Z
    Mar 2010
    Spring, TX
    1,082
    It seems like a lot of salt to add. Maybe I will just pass.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    I have heard the same thing as far as how the water feels. I was considering adding a little salt to reduce any eye irritation but have not decided one way or the other yet. Ill waite to see what others post.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    Jul 2009
    Seattle, WA
    89
    Quote Originally Posted by mynewpool
    I'm thinking about it too, it is a lot of salt but only $40-50 and almost no work other than lugging a few hundred pounds of salt to your pool. Got any kids? I think my nephews might be big enough...
    I think I might secretly put salt and borates in my hot tub and see if anyone notices.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
