Results 1 to 11 of 11
Thread: suction too strong while vacuuming?
    Mar 2010
    Huntington, WV
    150
    While I was vacuuming my pool the other day, the triangular head vacuum seemed to get stuck on the bottom and it took every bit of my strength to pull it off the bottom. It does has a pretty good suction. I did notice that after the water settled, the liner was wrinkled a bit in that same spot.
    Is this normal? I was thinking about getting the Diver Dave or Aquabug this summer, but what would have happened in this instance if I left the vacuum unattended?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    South Central NJ
    3,192
    Re: suction too strong while vacuuming?
    1) Pull a brush off the vac head to let more water in.
    2) Most suction side cleaners have a valve that regulates how much suction is allowed to go to the cleaner and allows any excess to bypass.
    Scott
    Owner of - PoolGuyNJ LLC
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It could be that your brushes are worn down. When they wear, the area between the vac head and pool bottom is reduced, creating more suction. They can be replaced on some vacs.
    If that's not it, you can use a skimmer plate to vacuum and drill relief holes in it so the full pump flow doesn't go through the vacuum.
    Mar 2010
    Huntington, WV
    150
    Quote Originally Posted by JohnT
    The vacuum head is brand new, only used about 6 or 7 times.
    Is the Diver Dave vacuum a side cleaner?
    24' AGP
    South Central NJ
    3,192
    Yes, It's a suction side cleaner. It is powered by the suction of the skimmer and made for AGPs.
    Scott
    It sounds like a faulty head to me, that or there is an area in your pool that has an irregular hump or something. It's quite simple. If the head is in good shape and operating properly it should not stick, providing the surface it is on is flat. When i moved in here a year ago, the previous owner was using a vacuum head every day that was virtually stuck to the surface 100% of the time.
    She must have had hellacious arm strength to run that thing. I went to the pool store and bought a new head and it now glides across the pool with ease.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Apr 2010
    West Hollywood, CA
    32
    BTW, I love my Diver Dave! Best automatic cleaner there is.
    [center:3jp7r7gm]15'x25'x4' Oval Muskin AGP, blue vinyl liner, sunk 2 feet in ground with redwood decking. Approx 10k gallons. Hayward Perflex filter D.E. and Hayward 1.5 hp pump. One return line. Wedding cake stairs. (whew, hopefully that describes the pool!)[/center:3jp7r7gm]
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I'll cast a vote for the pool rover Jr in a agp. Works great and operates independently of your pump
    Apr 2010
    West Hollywood, CA
    32
    @dmanb2b, as long as it's not the Baracuda Ranger Automatic Pool Cleaner! After years of having the Aqua Critter, Diver Dans etc. (we're talking YEARS of solid service) I saw the Baracuda Ranger and thought, well, why not try something different. Not only was it time-consuming to get into the pool but all it did was flap flap flop like some dying beast all around the pool and suck the liner (get stuck in one place too) and make loud noises! Didn't clean well at all! After two tries with the thing I threw it into the pool room and went back to the Aqua Critter/Diver Daves! What a waste of money!!! At least I can reuse the hoses to lengthen the Diver Dave.
    BTW, you can pick up a Diver Dave on Amazon for a steal right now! Best price I've seen online!
    Mar 2010
    Huntington, WV
    150
    Quote Originally Posted by catchyoulater
    Yep, with my discount, I should get it for about $87. The local pool store had it for $149.
    24' AGP
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Nope..not a Baracuda, rather a Pool Rover Jr. Wasn't trying to compare it to a Diver Dave either, just offering another alternative that has worked great for me. I can drop it in in the am and let the filter do it's thing during the day and not worry about replacing the skimmer basket...etc...that's all
