Results 1 to 10 of 10
Thread: Lots of tiny particles floating on top of pool...normal?
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Ok...I'm somewhat of a clean freak. But the teeny tiny floating particles on the top of my pool are really annoying me. I assume most of it is dust and pollen (there are some tufts of what look to be cotton mixed in, too, but I didn't think we had any cotton trees around here). I put knee highs on the skimmer baskets in hopes it would help. I could clean those dang socks every day b/c they are filled with icky gunk. I skim the pool every night and again every morning but the particles are mostly so tiny they just go right through the net.
    Is this typical? Is it just something I need to learn to live with?
    22,000 gal IG Pool & Spa, Fountain and Spa Spillway, Penatair IC-40 SWCG, Pentair Intelliflo Variable Speed Pump, Cartridge, Antigua Blue Wet-Edge
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Re: Lots of tiny particles floating on top of pool...normal?
    Probably dandelions.
    And yes, stuff on the surface is normal. I find little clumps of superfine black stuff all the time. At first I thought it was ash from barbequing upwind, but I get it even on days I don't barbeque and the lid is on tight.
    Try moving your return jets around, maybe improve circulation. That will keep the surface nice. Won't help much with the skimmer socks.
    Ohio
    217
    hawkeyes... I live in northern Ohio and you are describing a normal spring , early summer around here. We don"t realize how much **** is in the air till we get a pool. I have weed seeds, tree seeds, Charry blossoms, grass, bugs , frogs, and the list goes on and on. I live in the country and there is wild country all around me. It takes cleaning for me everyday to keep up. For me a solar cover and a skimmer sock help a lot but some still gets in. It does slow down in mid summer.
    I hope somebody responds to your question that lives in Texas that isn't so far away, but you are describing a normal process up north. I have so much stuff at this time of the year it might be making it to Texas.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by Richard320
    You bring up a good point about the jets and I wondered the same thing. Should they all be pointing in the same direction to keep the water flowing the same way? Not sure if I just need to go twist a few in the opposite way and see if it helps or what.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by ric
    I can't imagine what yours must be like being in the country---I'm in a large subdivision that has no construction going, no grass near the pool, very few trees and yet I have **** all over the surface. I guess I just need to get over it but I hate walking out there and seeing crud shimmering across the top of the water!
    Mar 2010
    Spring, TX
    1,082
    I have the same issue as you do with the net. I have a net that has larger holes and then I have a net that is used to get very fine particles. It is a black net and it will pick up almost anything except dust particles.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Quote Originally Posted by hawkeyes
    Yup...
    http://www.PerfectlyClearPoolService.com
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I have the same problem, but I live out in the country. My house is kinda in the middle of a hay field. I find that if I run my pump on low, the skimmer doesn't do it's job too well. About an hour on high and that little stuff is gone.
    They'll be cutting my hay as soon as RAIN isn't in the forecast That's always fun. Stuff flying everywhere. It's amazing what you find that is annoying once you've put a pool in I tend to pay more attention to the direction the wind is blowing too
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by orthofish
    I have so much to learn....there are different speed I can run my pump at??? Seriously....I need someone to come teach me this stuff.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,225
    Most common pool pumps are single speed. There are variable speed and 2 speed pumps available and people like them for the potential energy savings.
    Love TFP? Become a
    TFP Supporter!
