Results 1 to 10 of 10
Thread: Pool Builder unresponsive - what are my choices?
    Vero Beach, FL
    462
    My pool is still within the 1 year warranty. I've had two leaks repaired, but each time it took about 2 months for the PB to finally get around to fixing them. Now I have several other problems.
    I have 2 spots in the tile grout that are bleeding rust through. I told the PB about this 3 months ago. A large rust spot appeared in the wall of the plaster - I think it is rebar bleed through. Notified PB of this over a month ago. He replies to my voicemails occasionally, promises to send someone out "this" week, and then it does not happen.
    Other than notifying the BBB, what can I do. I thought of hiring my own people to fix the problems and then billing PB and/or taking him to court over the cost, plus $ for my time, etc. Or just taking him to court now over the fact that I think my pool is a lemon due to such poor workmanship.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Nov 2009
    Indialantic, FL
    323
    Re: Pool Builder unresponsive - what are my choices?
    Old saying - if it isn't in writing, it wasn't said
    If he is really unresponsive, you need something to prove you tried to obtain a remedy BEFORE the warranty expired. A certified letter? If you know a lawyer perhaps something on their letterhead would cause movement.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Guest
    I hate to hear this. It is so easy to just respond and handle things like this and maintain a reputation (assuming good one!) than see an upset customer and the repercussion from not addressing the issue(s).
    I'd make one last call and "suggest" that he pick a day and time that you can meet to discuss the problems and solutions. If he is unable to make that happen, I would advise him that you will be posting a complaint with the BBB and Contractors State Licensing Board. That costs you nothing, but puts a blemish on his record, which he would probably prefer not to have.
    Hopefully he will respond and address your issues. These are somewhat common pool issues, and relatively easy to fix. Less work than dodging phone calls and hoping he doesn't happen to bump in to you at the grocery store!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    lborne, I hate to hear this. Do you know where he lives or does he have an office? I have my PB home address, office address, and I also have all his full time workers phone numbers. I remember contacting some of them last year and they came out to regrout my skimmer box, and the other fellow came out and helped me replace my intellibrite light. Do you know how to contact any of his full time workers? It seemed to work for me......
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    Depending on your pool builder, you may want to try and get the contact information for the CEO or president of operations. I had a similar problem with getting a warranted item corrected and had to bypass the warranty office and contact the vice president of the company. If you can PM me the builder and if its the same one I have the contact information for you.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    Vero Beach, FL
    462
    Thanks all. The guy is a small time operation. He has a pretty good reputation. I know where his office is and he is just a contractor and subs everything out. I've called so many times and given him so many chances that I'm done trying that anymore. So I sent a certified letter today. Key points were all the problems I've had that I have fixed myself on the advice of his salesman because as he put it "its never going to happen if you let the owner handle it", all the current problems, and that I want it done by end of June.
    Also put in that I think all these problems prove "poor workmanship" and "poor quality", and that any future problems to do with rebar rusting and expanding will be covered under warranty since he is not fixing it promptly.
    We will see if it helps. If not, I'll report him to the BBB and contact a lawyer.
    Solar heat
    Vero Beach, FL
    462
    Re: Pool Builder unresponsive - UPDATE - help needed
    I came home from work today and there was a 1.5" diameter patch where the rust was bleeding though the plaster wall. I'm pretty confident it was done by my PB - the owner himself who I've been dealing with. Its pretty shoddy work and the patch is concave. I called and left him a message because my issues are:
    1. I specifically requested that no work be done unless I was present and for him to call me when he or the repair person was on their way. I can leave work anytime to be home.
    2. As of right now, the last thing the PB told me was that the stain was probably algae. Obviously he was wrong because you don't patch 1 algae stain.
    3. A pool repair professional (that fixed the leaks in my pool) said the rebar rust through will just leak around the patch and that this is a serious problem that needs to be fixed properly.
    4. I don't want a white patch in my brand new pool - I want it to match the plaster as close as possible.
    5. I want something in writing from the PB that says this is not serious and not rebar if he inisits it is not. Then give me an extended warranty in that area from future rebar problems.
    6. None of the other issues, including 2 other rust bleed throughs at the waterline in the tile grout, have been fixed.
    What can I do? Is there anything else I should be asking for from the PB?
    Solar heat
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Take pictures of the work that was done, write another letter detailing the situation just like you did here. Let him know you are not satisfied with the work and that what was done today does not relive him of his responsibilities.
    Love TFP? Become a
    TFP Supporter!
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    For what it's worth:
    If he shows up without you present, that would be trespassing. We have a dog (friendly) in our fenced pool area. All access is LOCKED when we are not home for her safety as well as others. Obviously something was open for him to enter. Our homeowners insurance gave us a lower rate for doing things this way. That way if someone does enter, it's a clear case of trespassing.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    chris4150's Avatar
    Apr 2009
    180
    You could always try your local media's consumer advocey group. Most local media outlets have a consumer aid group of some sort and love to expose problems such as yours. Just a thought.
    Chris.
