Thread: Better Pressure gauges available...????
    I am sick of replacing my 'el chepo pressure gauge every year. It always gets stuck in a single position that looks like the needle wrapped around past the max PSI reading and stays there. I have to replace it every year. Are there better higher end oil filled gauges available, that maybe have some dampening in them?
    If you can provide links to a few, it would be much appreciated!
    14' x 28' inground concrete pool - 14,500 gallons
    Hayward Cartridge filter C-1100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Better Pressure gauges available...????
    Look for a Fimco 0-60PSI gauge. Farm and lawn/landscaping type products use these. I just bring mine in the house in the winter. If your filter is outdoors, keep an old gauge to plug the hole during the winter.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Not sure if this one is any better, but it is the one I bought. I am installing this weekend.
    http://cgi.ebay.com/New-Hydraulic-Liqui ... 3a5b3c6768
    I liked the fact it is all stainless and was only 9.85
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    22,551
    There are tons of glycerin filled gauges out there. I'm buying a 0-30PSIG gauge instead of the usual 0-60PSIG because my pressure never gets nearly that high. Secondly I'm buying a bottom mount gauge and mounting it on a 90º elbow.
    There are a couple of issues with the "standard issue" gauge. First, it is cheaply made so it's prone to failure. Second is that after a bit of use a small amount of water gets into the bourdon tube (the thingy that makes the needle move) and then it will freeze and ruin the gauge over winter. There a few ways to help the situation.
    1. Buy better quality gauges[/*:m:1kp53nk3]
    2. Bring them inside in the winter[/*:m:1kp53nk3]
    3. Buy bottom entry gauges and mount them vertically with a 90º elbow.[/*:m:1kp53nk3]
    4. Buy diaphragm seal gauges[/*:m:1kp53nk3]
    The last option is probably cost prohibitive for most folks.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Quote Originally Posted by mcoonan
    Mike
    I just ordered a glycerin filled 0-30 PSI one from this same eBay seller. Thanks for the link!
