View Poll Results: Do you use adjustable returns or not?
Voters
18. You may not vote on this poll
  • Yes
    16 88.89%
  • No- Just straight returns
    2 11.11%
Thread: Use of adjustable returns....
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    My IG concrete pool has two returns. Right now their just straight returns, you can't direct the flow using the eyeball returns.
    Are you using adjustable returns or not? Any advantages either way?
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The eyeballs let you put more flow on the surface, which helps with moving bugs and debris toward the skimmer. You can also use them to help keep the flow from messing up auto cleaners.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have four total and I use one to point down into the deep end for deep water heating while the other three are used to push debris toward the skimmer.
    Mark
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    Quote Originally Posted by JohnT
    This is why I posted the poll. Seems like small leaves and stuff kinda just clings to the sides. I had the eyeballs on last year, just never put them back on this year.
    I wonder if more surace circulation leads to more evaporation.
    Kevin
