Results 1 to 11 of 11
Thread: red valves
    May 2009
    south jersey
    49
    red valves
    I have 10 red handle I think they are jandy valves they have a union on them so you can take them apart and lube them.
    Problem is the are so hard to turn that almost all the handle have broken off .. Its very frustrating I have the black valves for my drains the ones that you unscrew the top and can take the handle off and move they are butter smooth They might be called never lube ..
    I take apart the red valves and lubed them with pool grease from store but they should not be that hard to move kids can not turn valves anyone else have this problem pool is 3 years old valves are 1.50 and 2.00 inch
    Vinyl pool 37,000 gallons 2hp hayward , sand filter, true L 18-41-16-28 - 9 foot deep end .. Solar panels with goldline automation ..3/4 hp polaris 380 ..BBB method
    Dec 2007
    Central New York
    504
    Re: red valves
    Picture taken from this web site
    http://www.westsidewholesale.com/pool-s ... lves-plist
    These?
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    May 2009
    south jersey
    49
    Re: red valves
    yes thankyou
    22,539
    Re: red valves
    Even though they have the union fitting they're not really very good valves. The never-lubes are great valves and designed to be rebuilt. Replacing the red handled valves is the best fix.
    May 2009
    south jersey
    49
    Re: red valves
    Okay I need 7 of them weres the best place and brand to buy them at
    22,539
    Re: red valves
    Wow, 7. I think I'd try and replumb to reduce that amount some. Maybe replacing some of them with 3-ways. I don't know the best place to buy them but I'd do some serious internet shopping before I bought that many.
    May 2009
    south jersey
    49
    Re: red valves
    My pool has two skimers two drains two set of steps a swim in spa and six water shooters also has lines for water fall and slide
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: red valves
    Quote Originally Posted by twinsticks
    Pentair makes a valve that's similar to the Jandy for about half the price of the Jandy. I have two, and they look to be well made, but I haven't installed them yet so I can't comment on function or longevity.
    Nov 2009
    Indialantic, FL
    323
    Re: red valves
    I have the Pentair valves - on a new pool so I can't address longevity, but they function smoothly and seem as well made as the Jandy valves - same lifetime warranty as well.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Dec 2007
    Central New York
    504
    Re: red valves
    I bought mine fron here. Besure to look at all 6 pages of valves.
    Hotrod30
    Pentair VF3050 pump
    Apr 2010
    Las Vegas
    173
    Re: red valves
    If you need just one way valves I bought a few in the 1 1/2" and 2" size from Lowes here in Nevada for around 9 and 11 dollars respectivly they are all white including the handles and are call a Union valve. Way cheaper than a Jandy one way but does not come apart as easy.
    The handles turn nice however.
    20,000 gal. 32' x 17' freeform custom pool, 3ft. shallow - 8ft. deep end, Pentair Whisper flow 2.2 HP WF-6, Purex/Triton Nautilus FNS48 DE filter, 2 Intex Chlorine Generators (retired) SR Smith Rouge Rapids curved slide, The Pool Cleaner 4-wheel model w/Hayward large leaf canister. Tightwatt pool timer Spa: Beachport 5 person/350gal. Wishlist: move Neiko Tools pump to slide, solar system, Fountain, Automation. http://www.poolcalculator.com/
