Thread: Aqua Chem 1 inch stabilized tablet question
    May 2008
    I am trying to figure out the amount of CYA that is in a aqua chem tablet. the label says 99% trichloro, so im am curious as to the amount of CYA these contain. Anybody want to take a shot? Tried to find chemical content data online, but no luck. I opened with a low CYA level, and will be away for several days. Thought this might be a way to kill two birds.
    16x32 IG vinyl
    24000 gallons
    Hayward super pump 1.5HP
    Hayward Pro Series Filter S244T
    3 returns, bottom drain, skimmer
    Re: Aqua Chem 1 inch stabilized tablet question
    Trichlor adds 6 ppm of CYA for every 10 ppm of chlorine, it also lowers the PH.
    You can use the Effects of adding chemicals section in the Pool Calculator to answer questions like this one.
