Thread: SteveNbr's first official numbers
    Baton Rouge, LA
    237
    Ok... 2.5 weeks after plaster, here's my numbers:
    FC 3
    CC 0
    TC 3
    pH 7.2
    T/A 80
    CH 230
    CYA 25 (ish)
    Temp 85 F
    Not salt yet, but probably will be next week or so.
    I've been using muratic acid to control the ph.
    I've been using bleach to chlorinate.
    Plenty of areation to be had and sun to be tolerated.
    Prior to these, I had added about 5 lbs of cya, the last of it being 5 days ago. So I've just put a little less than a pound in some hose in the skimmer, to help bring this up.
    What's the goal on FC?
    Any comments on any of the other digits?
    Thanks!
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    Check Jason's calculator for suggested FC with an SWG. little chart fills in at the bottom as you enter your CYA.
    pH needs to come up to 7.6
    See this thread... read waterbear's post, ignore mine!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Baton Rouge, LA
    237
    Thanks!
    I printed out waterbear's comments, and will post them near my kit...
    So nice of you/him/everyone else to share their knowledge!!
