Thread: how long for cya
    May 2009
    Trenton NJ
    497
    how long for cya
    I put enough cya in a sock 3 days ago to get me in the 70-80 range (swg) and I am still getting a reading about 30 or so. Should the reading be going up gradually, I started at 30ppm.
    I read here it takes a week to get a good reading, do I need to be more patient? When do you get to a point when you just add more?
    I did backwash a few times, but nothing drastic. I am shocking at a cya of 30ppm. Today my fc is 4.5, it was 10ppm on monday, I am going to add about 3 gallons tonight. Oh my cc is .5
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mar 2009
    Huntsville, AL
    156
    Re: how long for cya
    CYA seems to take about a week to register on the test.
    Once I add it, I assume it is active and immediately adjust my FC target (i.e. FC minimum) up per the Chlorine/CYA chart at the following link:
    http://www.troublefreepool.com/pool-...ya_chart_shock
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Jan 2009
    Cupertino, CA
    1,966
    ethany, is the sock in front of a return or in the skimmer basket? If it's in front of a return, be patient; if it's in the skimmer basket, you might have lost some in the backwash.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Trenton NJ
    497
    Its in front of return. Monday will be a week.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Did it all dissolve from the sock? What was the % active ingredient of CYA?
    (I once bought some that was only 50% and didn't realize it till I tested and did not reach my target...then I read the ingredient content. LOL)
