Thread: Solar Cover Choices Chart - so which one?
    Exton, PA
    249
    Here is a link to a chart on Solar Covers.com. I am starting with a cover, to see if I can forgoe the solar panels, etc. I don't expect miracles here, maybe a 5 degree improvement, between any heat production and heat retention..
    Are their covers any good? They seem pricey, but I can live with it if they: A) produce "some" heat. B) retain heat. I know what to expect from these covers, just want to make sure I don't pick a dud.
    These are the covers available for my pool:
    Mil Style Warranty Longevity Heat Retention Heat Production
    8 Blue/Blue 3 Year, 1 Year Full
    12 Blue/Blue 6 Year, 2 Year Full
    12 Clear Bubble 8 Year, 2 Year Full
    12 Space Age 7 Year, 2 Year Full
    12 Transparent Black 5 Year, 1 Year Full
    16 Blue/Blue 7 Year, 2 Year Full
    16 Clear Bubble 10 Year, 3 Year Full
    16 Clear Diamond 10 Year, 3 Year Full
    The 8s, according to the chart, have poor performance.
    The 12s have good retention, but only decent heat production
    The 16s, specifically the clear, have the best heat retention and production.
    Again, all according to their chart.
    The clear bubble versions seem to offer the best performance in any thickness.
    The 12 clear bubble is $60
    The 16s are from $75-100.
    thoughts?
    http://www.solarcovers.com/cgi-bin/Shop ... rison.html
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Re: Solar Cover Choices Chart - so which one?
    I get the cheapest clear cover I can find. My experience is they all fail fairly quickly and thinner is easier to put on and off so you are more likely to use it. So, the more expensive ones aren't really worth it.
    May 2009
    San Carlos, Sonora, Mexico
    21
    I have a cover from first4poolcovers.com and it certainly seems to work. Using the black side the temperature goes up about 5 degrees during the day. However, much of this is lost during the night but there definitely is a gain over a period of days.
    I also use the white side of the cover to prevent the pool from getting too hot. This also seems to work but I don't remember any numbers since it has not been used this way since last June.
    The obvious disadvantage of these covers is that they are not cheap. However, after I figured in the price of the cover roller it did not seem so big.
    14,000 gallon in ground plaster pool with Hidrazzo goulstrem blue finish with infinity edge and spillover from spa, Pentair challenger 1 1/2 HP filter pump, 2 HP Pentair challenger spa jet pump, Hayward 30" sand filter, Pentair IC40 SWG, Raypack 5100 heat pump, Jandy Aqualink PS8 controls, Kreepy Krauly
