Results 1 to 10 of 10
Thread: Water just tested. What is the BBB to lower PH
    Is there anything I can buy at Wally World to lower PH? I keep reading "how to increase PH"
    Thanks
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Water just tested. What is the BBB to lower PH
    Muratic Acid - if you can't find it at WW try a Lowes or Home Depot, paint store, hardware...etc.
    Central Connecticut
    159
    Do we look for something called Muratic Acid or ..... PH minus in the pool chemical section? Is the Muratic Acid a chemical sold in the pool chemical section.? Sorry if it sounds stupid.
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    11,969
    No stupid questions....
    Muratic Acid (also called Hydrochloric acid) is usually found in the paint section - though some stores do put it by the pool stuff. YOu may have to ask...
    PH minus adds sulphates to the water so we don't usually recommend it.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    ditto to what FPM said, she beat me to the punch...
    Muriatic Acid can be found in both the pool section and the paint section. In the paint section it usually comes as 20° BAUME (31.45%). In the pool section I have found it as 14.5% at the same price per gallon as the 31.45% stuff, so basically twice as expensive.
    It has a tendency to give off fumes (the stronger stuff will fume more) so try to keep the wind at your back when pouring. It is wise to wear safety gear (hand and eye protection) to protect yourself. Remember, it is just another name for hydrochloric acid (HCL) so think chemistry class.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2010
    Spring, TX
    1,082
    At home depot and lowes, I usually find it outside in the plant section. Typically the pool stuff is out there as well, but I have seen it inside. So if you go to home depot or lowes, go out to the plant section and look around. If not ask. I have found a warehouse pool supply store and they sel it in 4 gallon boxes for 20.00 bucks or so.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Ashbourne's Avatar
    Western Piedmont, NC
    109
    I got some yesterday at Lowe's, on the cleaning aisle. It was $6.53 per gallon (20 baume, 31.45%). I didn't get a chance to check out the carton (4 gallons) price because I could not have carried it out and I was in a huge hurry, but the cartons were up under the first shelf, behind the individual gallons (on the floor level).
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
    Thanks, And this is safe for pool liners?
    Yes, if you are a little careful when adding it. You want to pour muriatic acid slowly in front of a return jet with the pump running. That will mix it into the pool quickly and be safe for the liner. If you spill some directly on the liner you should wash it off as quickly as possible and you should never add muriatic acid when the pump is not running. The fumes can be annoying, try to avoid them.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Ashbourne
    At lowes I have only seen it sold in 2 gallons at a time. The warehouse pool supply by my house sells them in boxes for 4 for around 20.00.
