Thread: Hair line crack in fiberglass..pic
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    So I was out at the pool and I came across this crack in the fiberglass by the seats on the deep end. It is hairline at best doesn't seem to move when I touch around it. Should I try sealing it with something?
    edited sorry forgot the pic!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: Hair line crack in fiberglass..pic
    Anyone have these on their fiberglass?
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I've not noticed any on mine, but I'm not sure I would notice anything that small. Especially if it was under water. Also, my FG is not a solid color anywhere. How did you find that????
    I don't know the answer to you question either.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    [quote="orthofish"]I've not noticed any on mine, but I'm not sure I would notice anything that small. Especially if it was under water. Also, my FG is not a solid color anywhere. How did you find that????
    I was cleaning around the outside of the pool and tried to wipe it off but it obviously would not wipe
    No one else has fiberglass cracks??? Great!
    DaveNJ's Avatar
    Toms River, NJ
    520
    Check out Overtons Marine site. Fiberglass and Gel coat section. There is also a marine repair kit available that allow you to duplicate the pattern/texture.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I have a bunch of little scratches like that on my spa. Definitely not cracks though.
    Ive asked the question here and have been pointed to some good sites / sources for epoxy / fiberglass coating sites. If it gets worse Ill look into it more closely. But for now its so superficial its hardly worth investigating further. Good luck.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
