Results 1 to 8 of 8
Thread: SWG Salt ?
    chrisjb8685's Avatar
    Blue Earth Cty., MN
    32
    SWG Salt ?
    For the last few years I have been using EcoWater Solar Salt which lists itself as 99.7 % pure. I use the same salt in our softener and have noticed that there have been some contaminants or something in the salt that has left a dirty ring in the brinewell and filthy water when the salt has gotten really low. Supplier couldn't really explain other than maybe a bad bag of salt, (although it has happened on two separate occasions.)
    Last year I had a real issue with some type of soil bacteria "eating" up my CYA and really struggled all summer with minimal satisfaction. I am wondering if it came via my salt.
    Is there a recommendation on what kind of salt to use for the SWG? Pool store has some but it is really pricey.
    Salt is getting low and I need to add some but am a little nervous as I've just gotten the pool cleared up.
    Chris
    5 year old 40k L shaped vinyl Salt-Water with 40k T-15 cell, Pentair TR -100 450# filter, zeobrite media, 4 returns, 3 skimmers, 1 1/2 - 1/3 HP pump Whisper Flo
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: SWG Salt ?
    I use Morton salt in the blue bag from Home Depot. It is about $4 for 50 lbs.
    Mark
    Blue Earth Cty., MN
    32
    Re: SWG Salt ?
    Quote Originally Posted by mas985
    Have you or anyone else had issues with "dirty salt?"
    Is the pool store salt that is supposed to be "super" pure really worth the price?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: SWG Salt ?
    Some people have had issues using salt with additives, but the rule of thumb here is anything over 99.4% pure and w/o any additives should be fine. Your issues last summer were related to something else; dirty salt could not possibly cause that. Your softener issues are likely not related to dirty salt either.
    Re: SWG Salt ?
    Pool store salt comes from the same salt as water softener salt. It is ground finer, and run through a sieve to make sure there aren't any large bits, but otherwise it is the same. In practice people sometimes find a pebble or two in several hundred pounds of water softener salt that wouldn't have been in pool salt, but otherwise there is no detectable difference.
    Blue Earth Cty., MN
    32
    Re: SWG Salt ?
    Thanks! I'll just stick with water softener salt then and make sure the purity is above the 99.4% recommended.
    Also, should I delete a post like this now that my questions have been answered?
    Chris
    Re: SWG Salt ?
    No, we prefer to keep things visible. That gives you some history the next time you ask a question, and lets others with the same question find their answer by searching and seeing what we told you when you asked, without us having to answer all over again.
    Feb 2010
    Houston, TX
    271
    Re: SWG Salt ?
    I know you already have your answer, but I wanted to say that the what you're seeing in the brine tank is most likely from the water, not the salt. Normally the only additive in water softener salt is rust remover, which will not cause what you're describing.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
