Results 1 to 8 of 8
Thread: Chlorine Usage
    Oct 2009
    SW IN
    14
    Chlorine Usage
    I just had a new liner installed. I am trying the BBB method. I am not sure if I am using an excessive amount of chlorine on a daily basis. I am adding 2 to 3 qts of 10% each evening. I have listed test results below. The pool is a 25000 gal Foxx pool.
    FC=3.5
    CC=0
    Alkilinity=110
    PH=7.5
    CYA=40
    I have tested the water each evening after the sun is off the pool. The TC is always .5. I use the pool calculator and add the recommended amount of 10%. I check the water the next morning and always get a reading between 3 and 4 TC. Same results that evening. The pool is in total sun all day. I just want to be sure I am on track. It seems like a lot of usage, but I am a newbie. Thanks for any advice.
    25k-30k gallon IG plaster/shotcrete
    Pentair 1 HP Hydropump
    C-9419 catridge filter
    Kreepy Krauly attack monster
    And ooooo, a diving board - WHO WANTS TO TOUCH ME? :)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Chlorine Usage
    Sounds about right to me. The only comment I have is that with CYA of 40, you do not want to let your FC fall below 3ppm and target 5-6ppm when your adding chlorine so that by the time your ready to add chlorine the next day your FC is around 3ppm.
    Oct 2009
    SW IN
    14
    Re: Chlorine Usage
    Thanks for the advice. I wondered if I should get the level higher to start. I will add another dose right away.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Chlorine Usage
    Quote Originally Posted by gotgone
    So try this, test in the evening, add your nitely dose, say around 7-8pm. At 9 or 10 pm, before you go to bed, take another FC sample. Then use that later sample to compare your morning results to, so we can get an accurate overnight Loss result.
    If you are losing more than 1ppm you should shock.
    Your loss of 3 or so during the day doesn't seem excessive esp considering full sun, no cover, right? But I suggest you try a higher target, say 7 to keep you above your min of 3.
    Oct 2009
    SW IN
    14
    Re: Chlorine Usage
    I ran a complete set of tests at 5:00 this morning. The chlorine level was at 4.5. The ph has climbed excessively. On sunday evening the ph was 7.5. This morning the ph was almost 8.0. At 4pm I did a complete retest on everything. The ph is still at 8.0. The FC is at 1.0. I am going to add enogh 10% to bring the FC up to at least 6. The cya level now shows 35. We have had no rain in the last 2 weeks. I did add approx 3/4 in of water last thursday. Any thoughts on why the ph rise. I lowered the ph from 7.8 to 7.5 using dry acid, last friday. Thanks again for any suggestions.
    Oct 2009
    SW IN
    14
    Re: Chlorine Usage
    Just another piece of info. I have the jets directed upwards to get better water circulation. Is it possible to have too much movement near the jets. I am not getting any aeration but the water is moving extremely fast approx 3 ft directly in front of the jets. This is the same area wher I have been adding daily chlorine and the dry acid solution.
    11,969
    Re: Chlorine Usage
    Pointing the jets up can cause the PH to rise, even if you aren't seeing the aeration...some pools PH just tends to drift up...
    Ideally, you should use muratic acid to lower ph - as dry acid adds sulphates to the water.
    22,548
    Re: Chlorine Usage
    You could try lowering your TA by lowering your pH with acid (which also lowers TA) and aerating to bring the pH back up (which doesn't raise TA back up). Our TA is 80 and our pH rarely moves from 7.5.
