Results 1 to 12 of 12
Thread: Diamond Crystal Salt Pellets
    Oct 2009
    West Chester, Ohio
    7
    I'm in the process of converting my pool to salt water so that I can use my new SWG system from Hayward (Aqua Rite) and was wondering if it is ok to use Diamond Crystal salt pellets (yellow bag). My local Costco is selling 50 lb bags for $4.99 and from the package it is 99.8% pure, however there is no indication on the package it can be used in pools. So my question is: is it ok to use this product in my pool? I know pellets dissolve slower than granular. All comments are welcome.
    10K gallon IG Fiberglass (Viking); Jandy AE1500 HP; Hayward CA4025 Cartridge Filter; Hayward CL200 Automatic Chlorine Feeder; Solar Blanket; Hayward 1 HP Super Pump; Hayward Aqua-Rite SWG (T-3 cell)
    Re: Diamond Crystal Salt Pellets
    Yes that will work, but the Diamond Crystal Extra Coarse Solar Salt in the blue bags is a better choice and should cost the same.
    Oct 2009
    West Chester, Ohio
    7
    Thanks for your response. Why is the Extra course solar salt a better choice? I know the pellets take longer to dissolve.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I'm pretty sure that's the only difference. I used some of both in mine, since they only had 4 bags of the solar salt. We added the salt while swimming, and the pellets were much easier on the feet!
    As Melt In The Sun said, it is just the small difference in time to dissolve. The pellets will work, but usually the solar salt is the same price so you might as well go for faster dissolving.
    Oct 2009
    West Chester, Ohio
    7
    I think I'm going with the pellets - they are cheaper and dissolving with me feel sounds like a new experience.
    Thanks for everyone's comments and feedback.
    Jul 2007
    Suwanee, GA
    528
    I use the yellow bad and it usually dissolves in about a half hour.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Oct 2009
    3,899
    Dissolving the salt makes the water a little bit cold! Not bad, but noticeable and interesting. If you stick your foot in a pile of pellets, the water is quite a bit cooler. Have fun!
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    When I asked my pool installer (Pulliam Pools) about this they said I HAD to use "Pool Salt" because the other salts had impurities. But I read here that the blue Diamond Crystal Extra Coarse Solar Salt is acceptable. Any thoughts or comments on the alleged "impurities" that may be in it? Maybe Pulliam was overly cautious.
    The blue "Extra Coarse" is 4.79/bag and the Pool salt is 6.39/bag so naturally I favor the Extra Coarse.
    Thanks in advance.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Every now and then there is a small pebble in the extra coarse salt, other than that it is exactly the same salt, just not ground up as fine. The pebbles, if you get any, are easy to remove once the salt has dissolved.
    Oct 2009
    West Chester, Ohio
    7
    Followup to my SWG experience.
    Ended up using the Costco salt pellets and had no problem dissolving them - took about 30 minutes. One interesting thing to note - I added 50 lbs less than recommended from the Pool Calculator and too my surprise the salt content was about 20% higher than I expected. I had the local pool store check it which confirmed the SWG digital reading. Maybe there was some salt in the water before I started or the pool is smaller than the mfg claims.
    Now I need to fine tune pump run time with the generator dial for the desired FC level. It looks like 7 hours filter time with a 50% setting seems to be optimal.
    Overall a pretty good experience and the best part no more adding the daily bleach. I highly recommend a SWG to anyone looking to ease their daily pool maintenance.
    There will always be some salt in the pool to start with, so that is presumably where your 20% extra came from.
