Thread: cleaning the filter
    cleaning the filter
    My pressure has been around 28-30lbs for the last week or so. I backwashed today to get it back down around 20 psi. Soonafter i did it was back up to 28. is opening the filter and washing the fins inside the filter normal maintenance? How often? How do you clean it? if i open the filter will i have to shut off a valve? The top of my filter is above the pool water level. Thx.
    37,500 gal Kidney shaped plaster pool with Cozy corner and hot tub; Pentair DE Filter; Pentair Whisperflo 2.0 HP High Performance pump; Model 320 Pentair Automatic Chlorinator; Nature 2 XG Clear Vision Filter; Raypak Heater
    Western Pennsylvania
    151
    Re: cleaning the filter
    Is this your first time using this filter? Did you add the correct amount of Diatomic earth?
    When I first5 had mine the instructions said to add 5lbs but the label I found on the filter sad 4lbs, mine no longer needs regenerating every hour.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
