Results 1 to 20 of 20
Thread: Please Help, My testing equipment from over the pond PICS
    Jul 2007
    Fareham,England
    41
    Please remeber I cant get proper testing equipment over here.
    Pool has been up for over a month!!! ( should I say Paddling pool)
    1St Pic My Pool.... ( Paddling Pool LOL)
    2nd Pic blue water
    3rd pic filter pump and heater
    Jul 2007
    Fareham,England
    41
    Question!!!
    1st pic Total alkality (Looking at the bottom square)
    2nd pic Free Chlorine (middle Square)
    3rd pic PH (top sqaure)
    How the **** am I ever going to get this right!!!????
    The pool looks good and Iam doing guess work. Might as well stick My thumb in the air LOL
    Jul 2007
    Fareham,England
    41
    Iam looking at this and thinking NO Chlorine?
    Even tho I put 100 grams in last night?
    Help
    Any one want to guess the PH?
    pH=about 15 haha!
    What time did you test today? If you have no stabilizer/CYA, and you tested late in the day, you can expect the chlorine to be gone. Sunlight (yes, even through the clouds/london fog/british mist/whatever) eats up your chlorine.
    If you have CYA and your chlorine is not holding overnight, (sundown to sunrise) you may be developing a problem.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Most of those strips require you to quickly dip it in the water and pull it out for the chlorine test, then to put it back in for 30 seconds or so for the pH and TA. After a few seconds, the chlorine test will be bleached out and useless. May be different than the ones I used.
    Jul 2007
    Fareham,England
    41
    stabilizer/CYA, whats this? were do I get it from!!! LOL
    I live on the south Coast of england first day of sun for 6 weeks..
    NO RAIN
    Whoo hoo
    I dipped in the pool and stil have my skin on!!
    Jul 2007
    Fareham,England
    41
    Quote Originally Posted by JohnT
    It told me to dip and move 3 times in a circuler way?
    and then take from thumb upwards as per my Pics.
    LOL
    I just feel Like iam wasting my time and money????
    Arizona
    924
    JohnT - I've never seen strips that instruct you to do it that way - I'm curious what brand would that be?
    Wampa - Some strips are just awful - only a few brands are marginally ok.
    Can you not get a drop test kit, anywhere?
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jul 2007
    Fareham,England
    41
    Please be my guest if u can find anywhere in the UK???
    There is a market over here...
    Might start 1 my self....
    Anyone any good on export?
    I will import.
    I did not see the first pic before... love the floating 'bar'!
    Since you will be draining your pool at the end of the season, I would just hit it with bleach every evening, and not worry too much about the stabilizer/CYA. You might use a tad more bleach, but you have a small pool, so it probably won't be that much different. I would use the Jasons calculator (see my sig) and figure how much bleach you need to get to 3ppm. Then just pour that in every evening.
    Glad you still have your skin
    SW Indiana
    9,199
    Quote Originally Posted by Buggsw
    I had the instructions backwards. For the HTH strips I had in the past, the instructions are basically to swish the strip for 1 second, then wait 30 seconds to do the comparison for TA and pH, then put it back in the water and swish it for 30 seconds for FC. The reason being that the chlorine will bleach out the TA and pH patches. I still have the bottle and use it for spare reel parts in my tackle box. The bottle has an expiration date of Dec of 96, so things might have changed since then.
    Jul 2007
    Fareham,England
    41
    Quote Originally Posted by The Mermaid Queen
    U all talk of hitting it with bleach. Went to asda today (walmart) no 1 has heard of liquid chlorine bleach. So will have to keep using granuels from Makro (cash and Carry)
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Does this help your search. It is simple disinfecting bleach... I am not sure how potent. You can read the label. I found this in the cleaning section of the website (ASDA).
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    We mean bleach like you would use in the laundry for washing white clothes. In the US the major brand name is Clorox.
    You need to know what concentration (again, here in the US 'regular bleach' is 5.25%, 'ultra' is 6%) Usually it says on the back of the label somewhere. The really cheap store-brands or generic brands are sometimes as low as 3%.
    You want plain old bleach, not thickened, or scented or anything fancy.
    Hope this helps!
    ETA again, since you have a seasonal pool, it would not hurt to use the granules, since you will be draining it anyway for winter. Read what granules you have (dichlor or cal-hypo) plug the correct product into Jason's calc, and away you go!
    Jul 2007
    Fareham,England
    41
    Quote Originally Posted by divnkd101
    [web]http://www.asda.com/asda_shop/rc04_products/web_rc04_b_products_detail.jsp?BV_SessionID=@@@@1936922052.1 186261275@@@@&BV_EngineID=ccceaddliieikjicfkfcfkjdgoodglo.0& product_id=1862820&from_panels=&trolley_page=/rc03_trolley/web_rc03_a_trolley_body.jsp&item_status=I&on_promo=No[/web]
    LOL The number 1 Thickend Bleach in the uk with a lovely Blue colour included....
    Sorry cant stop laughing.... No way iam putint that in the pool, Would only just put that down the toilet!!
    Hey, we're doing the best we can... to make you laugh, apparently!
    Guess I should have said no thickeners, no scent, and no color!! (Though blue in a pool wouldn't be bad, riiiight?? )
    divnkd101's Avatar
    Mar 2007
    587
    Sorry bout that. ASDA's website gives no description to the product as does our Walmart website. What do you use for taking out heavy stains from clothing????
    MIKE
    Jul 2007
    Fareham,England
    41
    Persil, Vanish,Bold 3, they are all washing powders.
    The only time we use bleach over hear is for down the toilet. Never in a washingmachine.
    Iam going to go to Asda to investigate today.
    It is interesting learning about how people form different countries clean their toilets!
  20. Back To Top    #20
    Arizona
    924
    Vanish is a toilet bowl cleaner in the U.S.A.
    Buggs
