Results 1 to 8 of 8
Thread: My DIY Aerator
  1. Back To Top    #1
    Ashbourne's Avatar
    Join Date
    May 2010
    Location
    Western Piedmont, NC
    Posts
    109
    My DIY Aerator
    Working on getting my TA down (before I found this fabulous place I'd gone to the pool store where of course they told me I needed to put in Alkalinity Up) - I added the first dose of acid last night - brought TA down from 150 to 130 and pH down to 7.2...so now I'm getting that pH back up so I can re-dose with acid.
    My eyeballs point up and break the surface but not enough for strong aeration, so thanks to Rangeball and dmanb2b's pictures and guidance, I was able to build this today. Hopefully this will make a difference!
    [attachment=1:1t055b37]aerator1.jpg[/attachment:1t055b37]
    [attachment=0:1t055b37]aerator2.jpg[/attachment:1t055b37]
    Attached Images Attached Images
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
  2. Back To Top    #2
    esim13's Avatar
    Join Date
    Oct 2009
    Location
    Denham Springs, Louisiana
    Posts
    320
    Re: My DIY Aerator
    Awesome I want to do one of these myself... maybe this weekend!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
  3. Back To Top    #3
    Ashbourne's Avatar
    Join Date
    May 2010
    Location
    Posts
    109
    Re: My DIY Aerator
    It only took about 1/2 hour to put it together, including sawing the PVC. Materials about $12. I may end up tweaking it a little (reducing length of the pipe that comes from the return to the elbow, and possibly from the elbow to the T).
    Tomorrow I'll post with a new TA measurement.
  4. Back To Top    #4
    esim13's Avatar
    Join Date
    Oct 2009
    Location
    Posts
    320
    Re: My DIY Aerator
    Have you ever thought of using a t straight out of the return, turned so that the left side of t is pointing top and right side is pointing down.. top of it to aerator and bottom to a 90 elbow positioned for circulation? I've been toying with it in my mind but not sure if it would have enough pressure to aerate and circulate.. any thoughts?
    GEAUX TIGERS!
    Pics taken 2012
  5. Back To Top    #5
    Ashbourne's Avatar
    Join Date
    May 2010
    Location
    Posts
    109
    Re: My DIY Aerator
    Esim13 -
    Well, ha ha, probably not so much that I thought of that as I tested it by accident. One end blew off my T (had the jet at the steps turned off, which created too much flow in the return I was using...too much for the aerator to handle) - so I saw first-hand how much that changed the flow to the aerator.
    I guess it depends on the pressure you're getting at each return. If I turned off the steps again it might work, but with them turned on it wasn't enough pressure through the aerator for what I wanted.
  6. Back To Top    #6
    Ashbourne's Avatar
    Join Date
    May 2010
    Location
    Posts
    109
    Re: My DIY Aerator
    After 24 hours of aeration we are now at 7.5 (from starting point of 7.2) so maybe after another 24 I'll be at 7.8...
  7. Back To Top    #7
    Ashbourne's Avatar
    Join Date
    May 2010
    Location
    Posts
    109
    Re: My DIY Aerator
    As of this morning, pH back up to 7.8.
    Added 2 qts. of MA to bring TA down to 110 and pH down to 7.2...now aerating again.
  8. Back To Top    #8
    Re: My DIY Aerator
    How do you attach that to the return?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
