Thread: Friend's Numbers, please advise
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    My friend is trying to start the BBB. Here are her pool store numbers (I'm trying to convince her to get the k-2006 since that's what I use):
    FC 2.6
    CC .1
    TC 2.7
    pH 6.8
    TA 0
    CH 0
    CYA 7
    She has an AG 21' round. This is the same as what I have so I know it's 10,400 gallons. Here's what I have planned for her:
    1 jug of 6% bleach
    14 lbs of baking soda
    3 cups borax
    3 lbs CYA
    I got the amounts from Pool Calc. Does this look/sound about right? I'm a little concerned with TA and pH effecting each other. Walmart sells the 12lb bag so should she just opt for that instead of the full 14lbs? My other question is what about CH? I know it doesn't matter much for a vinyl pool but I don't know what target to shoot for.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    22,553
    Re: Friend's Numbers, please advise
    If your friend is close enough you should test for her.
    The numbers you posted sounds suspicious. While not impossible it's hard to believe she has zero TA & CH. A CYA of 7 is sketchy too. But you probably already know all this.
    It hard for me to recommend adding anything except chlorine if I don't trust the numbers. If you turst the numbers your plan of attack sounds right.
    When adjusting TA from near zero, bring TA up to perhaps 40, then test and adjust PH to a bit lower than what you actually want, then test and adjust TA to the final target, then test and adjust PH to the final target.
    esim13's Avatar
    Oct 2009
    320
    Thanks guys! What about CH?
    GEAUX TIGERS!
    Pics taken 2012
    Since extremely low CH levels don't occur very often, we aren't really sure what happens when CH is zero. There is lots of experience with CH levels around 50 being fine with a vinyl pool, but not much experience below that level.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    CH probably isn't zero, but if they used a test strip that's likely to be the number it showed. I lived in BR for 15 years and remember the water being extremely soft.
