Results 1 to 15 of 15
Thread: Help.....want to switch from Sustain pool chemicals
    Central Connecticut
    159
    New member to TFP.
    I am switching from Sustain back to chlorine tabs in a Hayward CL 200 in line feeder. If I want to use BBB and use Bleach, do I still use the 3 1/2" tabs in the cholrinator and use bleach to shock or just use the bleach as my main source for chlorine.
    Also, just ordered my TF100 test kit. Tired of the frustration I get at the pool store! Different stores give different results and all lead to $$$ of chemicals out the door.
    This is a great forum. Thanks,
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help.....want to switch from Sustain pool chemicals
    Hi Rich, welcome....
    You can still use tablets, you just have to understand the impact they have on the water chemistry. Once you have your kit you'll have a better understanding of that...
    The tablets raise CYA and lower PH and TA. You can read more about how to chlorinate your pool on a daily basis in Pool School.
    Central Connecticut
    159
    Thanks. I can't wait to get control of the chemicals on my own. Do people find any true benefit from using the blue Pool Clarifiers ? or just wasted money?
    11,969
    Quote Originally Posted by richmgreen
    After reading the pool school, I am a little concerned. After having my pool water tested at the pool store, they had me add 9 lbs of solid stabelizer to my pool to bring the stabelizer level up ... Now that I am seeing that high CYA is very bad, maybe I should backflush to get some out. Just put it in over the last 2 days. The article says wait a week to get a reading on CYA after adding it. I don't want to wait and see it too high. Your thoughts. CYA was about 10 with FC 0. They also had me add about 8 bags of supershock to the pool. Ugh.
    That much CYA would make your CYA about 50, which is just right.
    What is the active ingredient in the supershock?
    Central Connecticut
    159
    I will have to check when I get home. The bag is Poolife TurboShock. The web site says the shock delivers 75% chlorine and will not raise CYA. Now that the water is clear, I need to vacuum but am told I shouldn't backwash for 3 days. However, the sediment must be causing a greater loss of FC.
    11,969
    I'm gonna split this off to create your own thread...hang on a sec.
    11,969
    Kk... the turbo shock is cal-hypo - so that's fine it didn't raise the CYA.
    The tablet use may be difficult since they had you raise the CYA up to 50. If you were at 30 it would prob be ok. It's up to you if you want to flush a little out.... or just use a little bleach each day (that's what most of us BBB'rs do. Test the FC each nite and add enough bleach to raise your FC up to your "target" (which keeps you above the "min" for the next day) see the CYA Chlorine chart for your targets.
    I know that BBB can sound like a lot of work, but it really isn't - just five minutes a day.
    You can still use tablets for vacations and such, or next season when your CYA is closer to 30.
    Central Connecticut
    159
    Thx. Maybe I will do a quick vacuum and a quick backflush and than see where the CYA ends up and go from there.
    Central Connecticut
    159
    Sustain made the process of maintaining the pool a weekly process instead of daily. does anyone know the difference between Sustain product vs 3 1/2 in chlorine tabs?
    Sustain is mostly cal-hypo, while the regular tablets are trichlor. Cal-hypo contains chlorine and calcium and is long term PH neutral. Trichlor contains chlorine, CYA, and lowers PH.
    Central Connecticut
    159
    Does that make Sustain better to use instead of the 3 in tabs? or is BBB the best way to go? Again, I am new to all of this, but have used both Sustain and the 3in tabs seperatley in the past.
    11,969
    It depends really what you want. Ideally, if money is not an issue I'd recommend an SWG. From what I have read, Sustain is super expensive. Trichlor is certainly usable - you just have to understand the affects of using trichlor and how to deal with those side effects.
    If you want my honest opinion, you should try BBB for 2-4 weeks before you decide if it's too much work or not.
    I knew a Rich Green who lived in Houston and kept an aquarium. He moved.... are you him?
    Central Connecticut
    159
    No, Not Him.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Sustain is territory controlled here, limiting your choices on where you can purchase it locally.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
